Still on your original battery?
Epiphany
Global
I like to disassemble things.
For those here that haven't died yet or gone back to living under a rock, I'm curious as to how many of you are still on your original battery. I'm still using mine. I picked up my factory ordered 5hundo on January 11th, 2020. Battery was stamped on 6/11/19.
Car is always being trickled and last time I tested it the numbers were all good. I'll check it again next time I'm in the shop but knock on wood, it has lived a healthy life so far.
AngelDeath
CH, New Jersey
'20 Shelby GT500 Rapid Red / '01 Metallic Red C5 / '17 White Overland
Mine is on the 4th, but not because of my doing, the Ford dealership the first 3 years when things were being worked on killed the battery and they replaced it since it happened on their watch, but my fourth which is what I am on, has been going 3yr+. goes on a trickle charger from Nov 1st to May 15th, so far holding well.
WD Pro
United Kingdom
Lime GT
Tut, tut, tut …
Another one who connects their tender direct to the terminals … :facepalm: :giggle:
I wrote this in June :
Who Leaves a tender on for less than 8 hours anyway ?
I’m absolutely with you, I just gave up quoting it and resorted to mild sarcasm … lol
I’m also still on my original battery but please don’t listen to me, I can’t even connect my tender properly … :facepalm:
Taken last month :
I only pulled the cover to clean the drain and check the battery terminals hadn’t disintegrated.
WD :like:
I’m also a 2020.
I’m a GT, but a fully loaded one with MR, so I guess my battery sees a similar duty cycle to a 500, or any other loaded car.
I suspect it helps so I will mention it - my modem and keyless entry are disabled.
WD :like:
skinnyb
Knoxville TN
Alex
21 Mach 1. FJG, Tremec, ESS G3X
Mach 1 here. Original battery, car built July 2021, put in service April 2022. So it sat a WHILE before being sold. Only had 4800 miles when I got it August 2024. I do keep on a tender thru the week every week, only take off on the weekends when I get it out.
Gilberjj
Vancouver, WA
Jorgen
2016 GT350R Base
I bought my 2016 in January with 2,804 miles. As part of the purchase, I had the dealership install a new battery, as it was still on the original. It was a little weak when I first started it, but that’s somewhat to be expected. The dealership had it for a few months.
Not a GT500 but…
Yep - still on original Motorcraft battery. My 2018 was a new car replacement due to Ford Buy Back of my 2016,. It currently has 41k miles. Started right up in driveway in the dead of a very harsh winter last year with no issues.
Car isn’t used as a daily anymore either - so it’s lucky to even get 3k miles on it in a year but that original battery is still kicking!
Epiphany
Epiphany
Global
Tut, tut, tut …
Bip, bip, bip...
I always connect negative to a ground on the chassis EXCEPT for that photo. I had just finished my ported blower install and was reconnecting the STB so I quickly connected to battery ground. It does not normally reside there but you caught me in the in between world.
wingnutt
@FL410
michael
350R Procharged w/P1X
Bip, bip, bip...
lol!
my 2016 battery finally died in 2025, and I only use alligator clamps when parked for >8 hours…
maybe you can get more than 9 years on the chassis ground? Only the shadow knows…
Inthehighdesert
NM
Charlie
I am. To be fair it’s on a tender to.
navbtcret
Warren, Pa
2021 Shelby GT 500
Mine is still on the original battery as well. I took delivery of my 21 500 in April of 21. When I pull it into the garage it goes on the trickle charger immediately.
RTFM
Atlanta, GA, USA
2022 Mach 1 premium 6MT ER
2022 and no trickle charging here. All good. I just started the car this weekend after 4 weeks untouched. Nothing to report.
But no modem and no WiFi anything. And no Ford mobile app. I also keep the keys at the opposite side of the house. And car is left unlocked in the garage.
Pudmullet
SE VA
Brian
2018 GT350R, 1970 CORVETTE LT1, 1965 GTO TRI POWER
Haven't looked yet but will. Haven't needed to. No tender yet. 2018 R, 2125 miles. May be original...???
radar
Melbourne AUSTRALIA
Ray
2017 GT Convertible 5 Litre V8
2017 Australian delivery
DEC 2016 build
38 000 kms / 24 000 miles
Garage queen. I’m in Asia most of the time. Storage guy keeps her covered indoors, on trickle before I collect her
Hack
Minneapolis
Mustang, Challenger
My original battery died last 4th of July when I was at Road America. It was on a tender most of the time when I'm at home, but that weekend it gave up the ghost after a lot of driving plus a fair amount of sitting. Not very convenient. I wish I had replaced it just in case just due to age.
