Spectre velocity stack vs ESS 4” intake
Brad1810r80
Huntsville AL
Brad
2018 Mustang 2018 F150
Did a 60-130 test this morning Spectre 3.75” velocity stack vs ESS 4” intake with S&B 12” filter. Did 2 runs each, 120mm pulley e85 full weight 74 degrees 2000DA. Spectre stack was little over $20. Link is in the video description.
Spectre 3.75 should work on any 3.75 inlet they also make a 4” version.
Spectre
5.57
5.61
ESS 4”
5.67
5.70
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
Question. Which did you actually test first?
If you tested the Spectre first, then it may actually be more beneficial than what the numbers say.
Many times, after fluids/oils heat up in the oil pan, tranny, and rear end, I see a .10-15 improvement on Dragy.... from 3-5 minutes prior.
Brad1810r80
Huntsville AL
Brad
I did a turbo guard a while back vs stock ess intake and it was no difference actually slower but within hundredths so really no difference.
Good data. Be interesting to have added a turbo guard to the mix to see if I findings in the past would match yours.
Brad1810r80
Huntsville AL
Brad
Spectre was first, but drove 15 mins to the spot , all temps were very close for all runs.
SolarFlare
S. Fla
2015 CO GT
yes I found a guard to be slower too.
Proshop
Billy
2021 Ford Mustang GT
Brad are you running it open all the time or just for this experiment?
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
There is def gains to be had with the proper inlet. Packaging is a big issue with all brands.
