ESS actual needs vs wants?
GrabberBargeCaptain
CA
Does the g2 also have less parasitic drag on the engine ?
HKusp
Hampton, Md.
Jason
I have a question. I was thinking about an ess g3x with g4 intercooler. I priced it out, parts, and installation..Because I have a 2017 with 40k miles, should I have the timing chains, tensioner, and phasers change before installation? If so, what brand etc...? 93 octane only. Never e85. Not available
If money is no option, it's not a terrible idea, but its a lot more involved doing timing chains than it is to put the supercharger on. The timing chains are SUPPOSED to be "life of the engine" but that's at stock power levels. That being said parts are over $600 and labor will probably double the cost of installing the supercharger. It has to be at least 10hours on the books.
Bob Lob Law
Jeff
'22 GT 401A ESS A10
I'm looking for the same power level as you and intend on staying on 91 octane with a G2/G3 120mm. Well, at least until it's a toy and not my daily. Even then the G2 can make 8XX on E.
TonyT930
Philadelphia, Pa.
Tony
2017 Mustang GT Convertible in Ruby Red
Thx for the reply. I've read that the 2017 5.0s cam tensioner can cause issues. Im just trying to decide what to do
HKusp
Hampton, Md.
Jason
Thx for the reply. I've read that the 2017 5.0s cam tensioner can cause issues. Im just decide what it is i will do
I've changed mine twice. Once when I did the built engine with the block outside the car, then re-did it in the car once, meaning re-timed the car, then replaced the whole timing set again both replacements were FRPP upgraded kits and the last time I added the Boss tensioners to it. All of that was chasing a cam correlation code. With a very competent mechanic, in the car both times, it took us about 15 hours start to finish. It's NOT fun. Now that's with a Whipple on the car which adds maybe 2-3 hours.
TXGTPig
TXGTPig
United States
Danny
So I'll say this. Unfortunately, I just had to replace my stock short block. The car has 39,375.2 miles on it. I asked my builder if we should change the timing set, and he said there was no reason. He knows I will be going FI very soon and what my goals are. I've worked with him in the past, and he's never led me wrong.
TXGTPig
TXGTPig
United States
Danny
NGOT8R
Adrian
2019 Bullitt
This is good info. I am right there as well looking to decide whether to replace those items as well. I guess the decision should be made on a case by case basis according to how things look. Do you have pics of what those compo e t’s looked like on your engine?
TXGTPig
TXGTPig
United States
Danny
I do not. However, they said everything looked clean and well-maintained.
Weeee
Utah
Tom
Mach 1, Mach E GT
Thanks for the help, and please feel free to chime in with any other information you think might be helpful.
Some additional points of consideration (as if it weren't complicated enough) for you;
  • Is this your daily driver? What weather conditions will you be encountering? My Mach 1 is a daily driver and is driven in four seasons of weather (except for major snow days).
  • What fuel do you have available at the pump? Are you cool with carrying around octane boosters in the trunk? I don't have access to fuel beyond 91 octane and I don't really want to carry around "just in case" bottles of octane booster.
  • Do you want to drive around on drag radials full time? I don't, nor do I want to stomp on the gas and feel death quickly approaching.
  • Are you cool with potentially having to rebuild the A10 sooner than expected? It seems like the clutch packs burn up around the 600 RWHP mark.
With those questions answered you can move onto the technical aspects of the build. My dream ESS build would be a G3 head unit, 125MM pulley and a TTR CNC Intercooled coyote intake manifold (assuming it actually works).
Why the G3 head unit? It's more efficient than the G2 at the same boost level. Why the 125 MM pulley? Low boost safety and A10 longevity. Why the fancy intake manifold? Because it looks awesome!
Happy building
TXGTPig
TXGTPig
United States
Danny
Yes. I'm in Houston, so it's Hot, HOT, & HOTTER, with a few days of "cold".
93 is on every street corner, and E85 is plentiful enough.
Nope. I have no plans to do a drag setup. It'll be street tires 24/7.
I never thought about this, as none of my research uncovered this issue. I'll have to do some more digging. However, like the old saying goes, you have to pay to play....right.
