ESS Supercharger vs Big Brands
Brad1810r80
Huntsville AL
Brad
2018 Mustang 2018 F150
You'd be faster boost for boost with a ESS and it has amazing support.
Brad1810r80
Huntsville AL
Brad
size blower the g3 is about same size as a novi 1500. If your talking cfm if you go what beefcake says I’d be slower only running 11 psi out of a f1a size blower than 11 out of a p1x
on an F1A sized blower…
SolarFlare
S. Fla
2015 CO GT
Novi 1500- 1400cfm
G3- 1600cfm
I wont discuss boost since its not necessarily a meaningful number. Gen 2 and gen 3 heads flow differently so that results in different boost readings which also change based on RPM, weather, gauge accuracy. Love you car, love that you're the only guy that least seems to be trying to go fast compared to the rest of the brochure guys. Its great to see blowers and centrifugals in general go quick on relatively easy repeatable setups. I just kinda draw the line on saying my stuff better than others, which seems to be a common statement coming from a few guys that love ESS stuff on FB.
Brad1810r80
Huntsville AL
Brad
You’re correct they’re all nice centrifugals and all of them make great power. There are some pros and cons to all of them.
Novi 1500- 1400cfm
G3- 1600cfm
robbievo
Socal
Rob
Looking
Your much better off with a procharger or paxton or vortech. much bigger dealer support network. you have hundreds of dealers across the country.
with our forum pricing, also can be bought for less. i'm sure they perform fine, but when you have shops all over the country selling and installing, you are going to have a much better support network.
Which kits can be had for less? I can't find anything remotely close to the $5,500 and $4,500 options from ESS.
Brad1810r80
Huntsville AL
Brad
He comes close with one of his kits , but it’s still Over $1000 more.
His is $6849 with bap and injectors
You can do the same injectors and bap with a g2 for $5695
Jackson1320
California
Jaxson
2015 mustang gt
I think he was saying that with forum pricing you can get the kits for lower then what they normally cost. I don’t think he means cheaper than ess
Brad1810r80
Huntsville AL
Brad
Mod for mod , boost for boost the other kits will NOT out perform ESS.
My car on 11 psi ONLY fuel mods BAP and 1050 injectors (e 30 for fuel) STOCK converter, big brembo brakes, k member , axles, trans. All of that stock. Decent 60ft (1.49) for a centrifugal car will get better with more seat time. Did remove passenger and rear seat.
beefcake
Bethel
2018 Ford Mustang
vortech / paxton, procharger have proven themselves time and time again.... to say that the other kits can't keep up is just silly.
there are cars all over the country going fast with both companies.
My car is the fastest with these 10 mods.. with my specific fuel mix, with my speciic weight at my specific track, with my specific, da, etc...
travel the country to national events with other cars with simliar setups and they will all perform....
Brad1810r80
Huntsville AL
Brad
Didn't say anything about they're kits not being able to go fast. All of them are great kits. I do believe from what I've seen at the track boost for boost and mod for mod. ESS will be faster.
