Shifter support bracket recommendations
NGOT8R
Adrian
2019 Bullitt
Here’s a video that I found which shows the difference between the factory support bracket and the Steeda support bracket.
Zrussian13
Phoenix
I’m having the Triax Street installed on my Bullitt next week but not the support bracket because I don’t want any increase in NVH.
Are you guys referring to this bracket :
Cheers,
WD :like:
This bracket shouldn't increase nvh at all. I've had mine installed for 4 years now. I forgot it was there until this thread started. Definitely helps with third gear lock out though.
SLOBullitt
Paso Robles, CA
2019 Bullitt
I got a smidge of additional NVH when I added this to my ride. Mostly past 5K rpm.
dead_inside
PNW
16 GT Prem PP
You don't want to attach the shifter to the tunnel again, when you change it.
FTBR and Blowfish are the solutions with the stock shifter.
Alternatively MGW and Barton.
This. I haven't used the Steeda bracket, so I can't comment on it. That said, what do you want? The FTB and Blowfish mount the shifter to the transmission. The Steeda unit is a beefier bracket but the shifter still remains mounted to the body. Between the FTB and Blowfish, the Blowfish includes a driveshaft safety loop and weighs more for that reason. Just some things to consider.
Bulutt
Australia
2019 Bullitt
Have you seen how thin and flimsy the factory support bracket is? You might want to reconsider adding the Steeda support bracket.
Yes I know but the OEM is mushy to absorb the vibrations and also as I have never had an issue with my gear changes I don’t see any reason to go for it yet. Once I get my short shift I will assess how I feel. Thanks.
Bulutt
Australia
2019 Bullitt
Without disputing your experience, it is not what the majority consensus is. As mentioned above, I will wait and see how I go. No big deal to do it later if I want. Wondering if Tim@Steeda has an opinion?
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
I'm always leery when a product states "No increase in NVH" and then I dive into the reviews and learn that is not the case.
WD Pro
United Kingdom
Lime GT
No increase in NVH if you accompany the mod with a loud exhaust and / or stereo volume modification ... :giggle:
For a period of time, one of the larger companies had conflicting NVH information / wording (for the same product) on their website depending on your region :facepalm:
WD :like:
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
WD :like:
I was thinking the same thing. The guys NOT experiencing NVH are the ones with long tube headers and a solid diff mount with a 1 piece driveshaft. :crackup:
NGOT8R
Adrian
2019 Bullitt
The way to know whether or not NVH exists is, if your teeth aren’t clattering, then there’s no NVH, on the other hand, if they sound like this, you have a serious case of NVH.
PC_GUARD
PC_GUARD
Fl
Scott
2016 Mustang GT PP1
I almost never have a shift error either however, the once in a while 3rd miss, is annoying. My sn95 track car was 100% NVH all the time. The car did not have anything rubber in it, and in most cases was aluminum bushed or delrin. It was like riding on a D8 bulldozer
Especially if youre showing off for a buddy you havent seen in quite a while lol
"Wow car pulls solid, until you missed 3rd noob" lol
Zrussian13
Phoenix
It's your car so definitely build it the way you want but did I miss something? Your saying majority consensus and I've only saw one person mention a "smidge" of nvh. Can't recall anyone mentioning nvh from that mod in any previous threads off hand either.
stang1087
Aaron
2018 GT Premium
I didn't notice much if any NVH from this bracket with the stock shifter. I found it was an incremental improvement on it's own. Since your 3rd gear lockout isn't consistent it may be enough but it isn't world changing on its own. You can also add the trans mount bushing insert to further firm things up. This will add some NVH though.
Zrussian13
Phoenix
The trans insert is hit or miss. Definitely stiffens things up nicely but in my case the nvh made it sound like my tranny was going to grenade. I did some research after that and it seems it's fine for most people but in my case it was terrible. It's super cheap though so your not out much trying it.
