BMS reset - no tools required
Farkel
Cartoon City, Nirvana
Marc
'20 GT Premium PP1, 2012 Jeep JK, 2022 Harley 48
After replacing my battery (with an AGM), I've been trying to avoid paying the dealer for a BMS reset, and I don't have Forscan or even a computer. I found the following on an F150 forum. Tried it on my '20 GT and it seems to work.
Procedure must be carried out within 10 seconds:
  1. Switch ignition on (engine off)
  2. Pull and release high beam 5 times.
  3. Press and release brake pedal 3 times.
  4. If successful the battery light will flash 3 times within the next 15 seconds
  5. BMS reset completed.
I'm not any kind of expert, but my battery icon flashed three times after performing these steps, so the procedure appears to work. YMMV
UPDATE: 3/3/2022
Confirmed with Forscan. This procedure resets the "days in service" to 0.
Elp_jc
None
Interesting. Now somebody with FORScan should watch what happens with that battery dash light :).
Thanks for that info it will help folks in the future!
scotty
London, Ontario, Canada
Scott
2017 Mustang GT
Thanks for this. Replaced the battery in my 2017 today and the procedure worked perfectly.
Farkel
Farkel
Marc
dirtwarrior
kentucky
Joe
2015 3.7 mustang
When I change batteries this will come in handy
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2022 F150 PowerBoost
Excellent info, thanks. I will be getting my car back from Shelby after a 10 month stay and I will want to change the battery, so this will come in handy.
What battery did you go with?
Farkel
Farkel
Marc
I don't know if that question was for me or one of the others who got new batteries, but here's my story. I wanted AGM for sure. First choice would have been X2Power from Batteries+. I've used them for years in my Jeep and they have a 5 year replacement warranty, but they're not available in the 96R. Second choice was Odyssey, but I had trouble finding one. Ended up with DieHard from Advance Auto, and so far so good. Any time it's in my garage, it's hooked up to one of my maintainers.
thompsje
MA
Jeff
2018 Mustang GT Premium
Thanks for this. I just replaced my OEM battery (01/2018) with an Odyssey, followed the procedure, and got the 3 flashes of the battery light. I'm still going to leave it locked up so it can be in deep sleep for 8 hours tonight, but figured this was a good process too.
I do have the Forscan tool but I'm really new to it... Is there a way to check the BCM status later to see that it successfully reset? would it just pull it in logs I could read?
Johnnybee
Canada
2018 convertible
Great info, as I see a battery replacement in the not too distant future. I was thinking AGM too but I read that they can cause issues with the charging circuit of the car. I also read that the typical battery charger (charger, not tender) can mess them up as well.
Rapid Red
Woodstock GA
Greg
Thanks for taking the time, finding and posting.
Well Done
Farkel
Farkel
Marc
Rapid Red
Woodstock GA
Greg
If it works for you or anyone else, you're welcome.
Owning a 2020 also, it is a sure bet when needed, C&P the info to a doc, and stored.
:thumbsup:
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
For what it's worth I needed to replace my battery while on vacation. I took out the stock flooded acid and replaced it with an odyssey AGM, I did not have forscan with me. When I got home, about a week later I hooked up and discovered the car had learned it had an AGM, it's cranking amps and reserve capacity.
So it appears the cars self learn.
DougS550
Indiana
Doug
2019 GT PP Whipple Stage 2
When you switched your battery, which one did you go with? Did you get a light or fault code or are you doing the reset to be safe. Thank you for your help
