PPF questions
Charlemagne
Czech Republic (Europe)
Nick
@LikeMike The matte part doesn't have PPF on mine. My detailer had precut hood glossy PPF which includes the glossy part of vinyl and precut matte PPF for the matte part of the vinyl, we tried it with it but it had air bubbles so it was removed and only ceramics was put on the matte part. The matte part is pretty rough and looks quite resilient, lot more than the glossy part of the vinyl.
The only disadvantage of putting PPF on the glossy part of the stripe is that you'll basically lose the Mach 1 logo in it, i wrote about that before. There's issues no matter what you choose. I'll have the logo re-created on top of PPF.
Possibly the best solution is to remove the stripe, put PPF on the hood and then put new stripe on the PPF and apply ceramics on it to protect it from holograms on the glossy part. Or to cut around the stripe if they can do it precisely.
Zelek
Hutto, TX
2021 Mustang Mach 1
It basically sounds like if you don't have a specific color of Mach 1, you can't do PPF on the vinyl emblem because of the differences.
LikeMike
NYC
2022 Mach 1
I see thanks
LikeMike
NYC
2022 Mach 1
I think I might be the only one who wants a satin clear wrap (for a shadow black). Everyone is focused on the matte portion decal and I'm not really sure what to do with the glossy part!
RonsterGT
Canada 🇨🇦
Ron
‘22 5.0 GT/‘16 F150 XLT/‘21 Explorer Platinum
I was told the same, it also costs your second leg (PPF costs arm and first leg). I'll rather use just lot cheaper nano sealant in spray every 3 months or so for the same effect as ceramics would have on the already superhydrophobic XPEL.
Wolfgang Si02 silica spray is AMAZING on clear coat and/or PPF.
If properly applied and cured, you can easily get 100+ washes out of it before it needs touch up.
I re-apply every so often because...why not? And it does layer a little so the shine and slickness is wicked awesome!
Ssjvegeta003
California
Cory
2014 Ford Focus ST3, 2022 Mach 1 HP
could anyone chime in on why knifeless tape placed around the vinyl emblem's outer edges isn't the easy way to bulk install a single PPF sheet over the whole hood? I have 3m bulk PPF was going to try the Knifeless tape with a single sheet, but I feel like I am missing something.
TonyNJ
Northern NJ
www.instagram.com
Tony
Knifeless tape won't cut trough the PPF the way it goes through vinyl. PPF is much thicker and stronger. Also, PPF goes on wet with soapy water and is stretched across the panel, which will probably cause knifeless tape to move.
You have to use an actual utility knife.
I've Installed plenty of both.
