Larger Diameter Front Tire Question
Snoopy49
Earl
2013 GT500 - SOLD and 2020 GT500 - SOLD
I need to increase the front end clearance so I can avoid destroying the belly pan attached to the front splitter when I pull into the driveway. So I am thinking about replacing the front tires with 305-35-20 Michelin Sport 4S. These tires are an 1" larger in diameter, so that should raise the front of the car about 3/8" to 1/2" higher.
Can anyone think of a reason that this could effect any of the systems, like the ABS, on the car?
Tomster
Beware of idiots
Tom
It shouldn't. Instead of doing all that, maybe install sliplo pads on your splitter and pan? How close is it?
Snoopy49
Snoopy49
Earl
It scrapes every time I pull in the driveway. I could probably clear with an additions 1/4" to 3/8" clearance. I think the Sliplo pads would make it worse
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
Snoop, I don’t see an issue in any way.
I have the sliplow on my car and they work mint. I think for you they would net you 3/8” LESS clearance, but when you rub it would be the sliplows rubbing, not your car.
That said, I would hate to hear the noise every time, and I would probably go up in tire size like you are thinking.
Snoopy49
Snoopy49
Earl
I had the same problem with my 2013 and when I replaced the POS GY's with Michelin AS3's, I replaced the front 265-40-19 with 275-40-19 and that took care of my problem. I never installed the lower splitter on the 2013 because of the driveway entrance and it is still sitting on the shelf.
protraxduner
OK
2020 Shelby GT500 Race Red
BE careful, while mine is different in the fact that i went wider and further offset. Going up from 30 to 35 (in my case 25 to 30 because of 21") the additional height, and likely additional width caused me all types of issues. I would not do again and stay with regular OD. My fender liner is all sorts of massaged, adjusted and cut to clear....and i mean BARELY clear. Luckily the fender liners are cheap and when i go thru these tires i will get new liners. My tires are 325/30/21 up front on 11.5 width wheels. Again different but going from 305-30-20 to 305-35-20 in my opinion...is going to be really close.
AMBJR
ALLEN
03 Mustang Cobra-20 GT500
Earl, I run 325/30-R20 on my 2020 KF GT500!!!
Melmark93
Iowa City
Mel
2020 GT500 Kona/White stripes, 93 MarkVIII Vortech, 94 Mark VIII, 13 MKS Ecoboost
I added an abs skid plate to protect my sho n sto plate bracket. Made out of a 6x6x3/4" abs block. Its sort of like a super slip low and is held on by the 2 splitter bolts. It takes lots of abuse.
Jmeo
You said member ;)
Massachusetts
Jaime
Earl, I ran 315/30/21 on the front of mine when I had the Signature wheels on AND I lowered the car 1/2" with the CFTP springs. The slight rubbing I had was due to the width and offset, not height. I honestly think changing your tire profile from 30 to 35 will not cause issues for you, especially with the stock springs.
Essentially you will be doing the opposite of a 1/2" lowering by spring swap by using a taller tire instead. The CFTP uses the same size front tire as the base car with no issues, and it sits roughly 1/2" lower. I think you will be fine.
AngelDeath
CH, New Jersey
'20 Shelby GT500 Rapid Red / '01 Metallic Red C5 / '17 White Overland
I didnt read all the replies and I'm sorry if this was brought up, but when my Vette I had the same issue, and there are wheels that attach to the front fram exactly for this so the wheels take the brunt and roll up the driveway opposed to the front end.
Manny231988
Roswell NM
2017 Mustang GT 2013 GT500
Lol you want to sell the splitter for the 13 ?
Snoopy49
Snoopy49
Earl
It is going to the new owner when I get ready to sell the car.
kz
West Chester, OH
Mustangs & F150
Not sure how your driveway looks but I've seen people with low cars put Bridjit curb ramp right in front of their driveway. (can't paste the link since work PC doesn't allow for that)
