Larger Diameter Front Tire Question
Snoopy49
Snoopy49
California
Earl
2013 GT500 - SOLD and 2020 GT500 - SOLD
I am not allowed to place anything in the gutter. I did try placing wooden planks in the gutter just to see if it was a viable solution, but no matter what I did, the car still contacted the slope to the sidewalk. There is a hump in the approach and I tried to have the county grind it down, but they said it was to code, so no go. To bad we don't have the auto lift like the new C8 Corvette.
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
Time for Airlift suspension buddy
kilobravo
Corpus Christi, TX
kilobravo.com
KB
'16 CT6, '18 SD, '20 GT 500
"Not allowed," huh, Earl? I understand not having junk cars in your front yard but that seems a bit over the top to me. City or owner's association rule?
I think your tire idea is the best short of a gutter bridge but Jaime's solution would certainly eliminate the problem. Thing is, as daffy as I am, my brain would be somewhere else arriving at the house and I'd forget to "pump me up." <laughing> I KNOW I'm gonna forget to fold the mirrors on the truck one day before I put her in the garage and the passenger mirror will hit FOR sure. :-)
Big John
Tulsa Oklahoma
2020 GT500 CFTP
Maybe I’m a little too red neck, but I would fix the driveway. Find a vender that will do the project on the weekend with out a permit. Better to ask for forgiveness than to ask for permission. I can neither confirm nor deny having done this many times in the past.
Rapid Red
Woodstock GA
Greg
Is it only the driveway, how about backing in ?
KISS ?
SEERED
Ridgecrest, Ca
Curtis
20 GT500-LOUDMOUTH LIME
I actually took the grinder and a squirt bottle of water to the high spots on my driveway entrance. That plus the Sliplos really helped. It went from catching an edge to a slight rub. overstating the obvious, go slow and approach at an angle.
SEERED
Ridgecrest, Ca
Curtis
KB, one thing that also helped me and may not help Earl is the fact that the grinder took off the broom finish of the concrete. Many concrete finishes are abrasive by design and just removing the rough interface made the splitter abuse go way down.
kilobravo
Corpus Christi, TX
kilobravo.com
KB
I can definitely see how taking off the rough brushing marks would reduce the grit of the concrete, Curtis and that may be something Earl has considered. But he is one of THE most thorough individuals I know and I feel sure he's looked at every angle.
Snoopy49
Snoopy49
California
Earl
I bought a pair of Michelin PS 4S 305/35 ZR 20 tires for the front and had them mounted and balanced earlier this week. The tires were suppose to be 1.2" larger in diameter than the 30 series, they should have .600" more clearance at the center of front hub, slightly more at the front splitter.
Unfortunately that doesn't seem to translate to real life. Having said that, I can now use my race ramps without the extenders and I think that I can avoid scraping the driveway if I can find the sweet spot.
Can someone measure the distance from the bottom center of the wheel (outside edge of the rim) to the ground on a base model with 32 psi in the tires.
With 305/35 ZR 20 tires my car measures approx. 2 7/8".
I contacted a couple of concrete contractors about grinding the entry smooth, but none of them would touch it because it was controlled by the county and it would cost $700 for the permit and replacing the concrete would require the same permit plus demo, materials and labor. So that was out of the question.
Epiphany
Global
I like to disassemble things.
Americans with Disabilities Act. Use it to your advantage.
When was the road, sidewalk (if there is one), and drainage swale constructed or implemented? Does the slope of the swale exceed 1:20?
Snoopy49
Snoopy49
California
Earl
The construction was in 1959 and the road has been paved many times since then.
Could swale be considered the rise from the road to the sidewalk?
Epiphany
Global
Approximate date the road was last paved, the swale was touched or the sidewalk? This matters quite a bit.
Of concern is the slope from the road to the swale and then back out of it. A picture of it would help.
Snoopy49
Snoopy49
California
Earl
The 305/35 ZR 20 Michelin tires on the front raised the center of the splitter 5/8" to 6 3/8". So the tire specs were spot on +.600" radius.
