Is the 5.0 designed for boost?
Scootsmcgreggor
CA
2016 Ecoboost turned GT
The predator was built for boost. The ecoboost was built for boost. Go and find all the differences between those motors and the coyote and there lies the answer. I have stock predator and gen3 5.0 short blocks in my shop now, side by side.
How do you figure the Ecoboost was built for boost? Well partially I suppose. But open deck block and boost pretty much never go well together.
engineermike
La
2018 GTPP A10
I think there are a lot of questions and not a lot of *real* answers. Yes ecoboost is open deck block and cast pistons, but handles 20+ psi on pump gas just fine. OPG? I believe GT500 and 350 use powdered metal gears with rare issues, if any. 5W50? Maybe the increased damping helps OPG hold up better, or maybe the higher viscosity puts more stress on them. Tight ring gap? GT500 and all ecoboost motors use about .010 ring gap. FWIW the 3.8 buick turbos ran lots of boost on cast pistons.
Kennysum1
Huntsville, Alabama
Kenny
2017 Alfa Romeo Quadraflio, 2018 TT GT Prem, 22 GT
My thoughts are it's blown out of proportion. I won't be doing OPG's to any future Coyote that's for sure.
I'd be more worried about the tight ring gaps vs hyper pistons with boost than I would OPG gears.
Well from my real world experience and loss of a entire motor and 15k replacing it with an actual built engine... OPGs are a must.
I knew the car was on borrowed time using the stock OPGs. I just did not care because I planned on the RPG short block anyways. With OPGs and GT500 intake etc.
If you are running a mild tune at 600 to 750 hp sure you will probably be fine for a long time. But just know that the OPGs are the weak point. Spend the money on them if you want to keep that engine or start saving for a built short block.
This was on a twin turbo setup pushing 1000+.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
The gt500 Def has a forged steel crank sprocket.
Gnatsum21
Fort Lauderdale FL
Former: GT 21 Roush Twister Orange RIP | ECO 2016
Same here man. I pushed a stock gen 3 to its limits for like a year. If I had replaced the oil pump gears I would probably still be on it.
But I was planning a engine swap anyways so went the cheap ass route and ran the stock motor until they gave out. It lasted wayyyy longer than I thought it would on 14.5 psi of boost. Hell a lot of it is still usable.
Got a RPG short block going in now though. Built for the power.
Hello, where would I get "Oil Pump Gears" for a GT 2021? My engine has a Roush phase 2 installed. Do you have a link I can lookup, please? Thank you!
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Kennysum1
Huntsville, Alabama
Kenny
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Yea
Just google Boundary Oil Pump Gears 2021 Mustang
Based on my personal experience with Boundary oil pump gears, I'd HIGHLY recommend not using those. Look like the Cobra Jet OPG I currently have are discontinued.... I'd recommend Accufab OPG. Long story short. I have pulled 3 sets out of my own engines that were FI making big power. CJ, Accufab and Boundary. CJ and Accufab looked perfect, Boundary was all chewed up.
gimmie11s
SoCal
Murica!
And my experience was the opposite where the OPGs were the only thing that lived.
And Boundary gears are trash.
Stick to FRPP (cobra jet) or Accufab.
Gnatsum21
Fort Lauderdale FL
Thank you, too. Just started watching a video on how to change those gears (just another brand) ..good grief! I will have Steeda do it. 🤪
wazslow
PA
2016 Mustang GT/CS
It's time consuming, but really not that bad.
schmeky
West Monroe Louisiana
David
2018 Mustang GT, 2024 Mustang GT
Get the Ford Motorsports heavy duty oil pump gears. I would not run anything else.
schmeky
David
80FoxCoupe,
Awww, shucks.
Thanx, nonetheless.
Wonder if you can mill the GT500 gears to the same thickness as the GT?
