Horrible understeer
Bluemustang
2015 Mustang Base GT
an alignment doesn't fix the squirrely IRS. But if your level of investment is going to be the absolute leastest, then sure an alignment can help.
I'm interested in FIXING engineering mistakes.
An IRS that can move and deflect all around is an ERROR.
A diff that can bounce all over the place and has the WRONG freaking bolts in the rear is an ERROR.
A set of shocks that are underdamped in rebound is an ERROR, not a "preference".
Exactly. There is so much I could go into - but just to point out one thing. The IRS in stock form is HORRIBLE. Anyone who has seen a video showing the deflection would have to be scared shitless driving the car hard with it like that.
TeeLew
So Cal
Tim
I have ride-height adjustable coil-overs. :)
But point taken. I probably should have said "stock'ish RATE rear springs"
Gotcha. I think that's all that's necessary, at least for a 200tw tire. Ya, you can run higher rates, but I just don't see any advantage to it.
1958cyclist
Gibsonia, PA
Mark
1985 Mustang GT, 2016 Focus ST, 2017 Mustang GT
OK, now that I have 99% of my suspension mods done, Steeda stop the hop, knuckle bearings, 200/800 springs, good struts and shocks, all the normal upgrades. It plows like a Mack truck, even with 295/35 19 R7's square
I read a lot where people recommend larger front sway bars?? Wouldn't this make it understeer more????
So what should I do to balance the car out. HPDE type events, no competition other than me against me per lap.
Thanks
Yes, camber plates properly adjusted will certainly help keep as much flat tire on road surface as possible. I have a similar setup to yours: Steeda Sport Springs, with 295-30-19 front and 305-30-19 rear. Everything else is stock PP1. The course I frequent is very tight and technical so I've found that -2.9 camber seems to work pretty well for the occasional track day. I leave it set at this setting for street as well. It's not a daily driver, so I'm overly concerned about tire wear.
Flyhalf
CA
www.youtube.com
Alessandro
Mustang GT 18 10speed auto PP1 , GT500 '21
Pressure is 43 hot
Yes more spring is needed.
Well. I think you find the issue :)
43 hot is .
Just too much.
34 is optimal. Lower even better.
Yeah i know. Hoosier suggests that. It is just the joke of the race community tho. At 46hot simply...there is no grip .
They do.that to protect themselves.
I run 30 hot. But for time trials. So 34 -36 hot for longer stints is perfect.
Reduce the pressure to 34 hot. And pls report the result.
Feel free to share your video too.
That is where i can be helpful in case you have some other issues 🙂
K4fxd
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
TeeLew
So Cal
Tim
There are 2 types. Through bolt spacers with extended studs are every bit as robust as a wheel with a longer hub. There's no physical difference.
If a 5-lug nut came loose, then it likely wasn't tightened correctly. If they tightened the wheel on with the spacer not seated, that could cause the problem you mention. This is not a problem with the parts. It's a problem with the mechanic.
luc
CA
2017 GT with PP
That is nonsense
The correct type of spacers do not add any more load than a wheel with the same effective offset
luc
CA
2017 GT with PP
Running-3.2 on the street is quite extreme and obviously the factory pp1 front wheel has too much positive offset for the amount of camber
shogun32
Northern VA
you can safely run 5mm worth of spacer on the stock lugs. Does that solve the problem sufficiently?
luc
CA
2017 GT with PP
Correct but i was not going to suggest it due to the dislike for spacers
Used to run pp1 rear in the front with 5mm spacers
Dave2013M3
El Segundo,Ca
2024 BMW M2 G87 6MT Toronto Red, 2025 Ford Bronco Badlands 2dr. 7MT
Sorry, R7 wheels? What sizes and offsets. You said square setup, so wondering if you are talking about a 10" wide wheel vs. an 11" wide wheel. Sorry never heard of these unless you mean the R357 SVE wheels.
