Horrible understeer
19VelocityBlueGt
Farmington
2019 velocity blue gt pp1 10r80
Bump steer kit will fix it right up. You have to get the suspension geometry back correctly after doing springs. As the front tie ends are fighting their self. Done this to mine and was night and day difference. Must do mod with lowering springs.
Bulldog9
Northern Virginia
2020 Bullitt, 2017 Tundra TRDPRO, 1976 Porsche 912, 1989 Porsche 944S2
Dave2013M3
El Segundo,Ca
2024 BMW M2 G87 6MT Toronto Red, 2025 Ford Bronco Badlands 2dr. 7MT
K4fxd
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
I don't have my notes in front of me but around 36.
I was deliberately overdriving.
So the plan is to drop the air pressure. Run some laps then add the spring rubbers and run some more. I don't want to have 2 alignment settings so will keep the -2.5 front. This works well for me on the street with my street tires.
If after the above I might add sways.
Really I started this thread to have you guys tell me I needed sways. :) Want to justify the new toys.
Anyway I think you all have helped my setup. Thanks.
TeeLew
So Cal
Tim
That's often my error as well. It's easy to over-charge a corner and then you just have to wait *forever* before you can get to gas. It's super frustrating.
luc
CA
2017 GT with PP
T11 at Laguna being a classic example ….
Flyhalf
CA
www.youtube.com
Alessandro
Mustang GT 18 10speed auto PP1 , GT500 '21
Flyhalf
CA
www.youtube.com
Alessandro
FYI...
I run 28mm Hub centric spacers..on track..and on street. since 17k miles.
And you know ..I push hard on track lol
Hub centric ( NO THE ONE WITH EXTRA BOLTS) are safe and proven muyltiple time to the race community.
alessandro .
shogun32
Northern VA
then don't take your street wheels to the track. Changing camber is just dumb.
your fear of thru-bolt spacers is irrational and without cause. Your buddy clearly did not torque things properly. Wheel lug bolts are NOT designed to take the sheer forces, the clamping-induced friction is. Any spacers you use should not be painted for this reason. Anodized is fine.
Radiation Joe
Allentown, PA
2017 EcoBoost PP Manual Recaro
I always trail braked into that one. My problem was oversteer on exit. Especially terrifying because there was astro turf on runout there way back when.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
That sounds like an excuse to get a new street set with a more aggressive offset. AmIRight?
