Horrible understeer
luc
CA
2017 GT with PP
I always trail braked into that one. My problem was oversteer on exit. Especially terrifying because there was astro turf on runout there way back when.
…and the astro turf was always full of marbles….
luc
CA
2017 GT with PP
Spacers are 100% safe if used correctly. For example hub centric design require hub centric spacer
So a failure , as you described, is always due to operator mistakes
In that you’re right that it add a level of complexity and risks compared to no spacers
As for you being able to run 305 with no spacers, you should precise that there is downside to not using spacers in that you can’t rotate your tires. Which is quite a big issue on track tires
luc
CA
2017 GT with PP
Ok, you can’t rotate wheels
Flyhalf
CA
www.youtube.com
Alessandro
Mustang GT 18 10speed auto PP1 , GT500 '21
The best part of actually racing your car is giving zero cares what it looks like.
......naaahhhh we are still proud of how it looks c'mon.
Imagine F1 dirty with water spots. There is some attraction to have a beautiful car☺
kz
West Chester, OH
Mustangs & F150
Why ? It's not exactly stanced look but most importantly, why do you give a shit ?
Bulldog9
Northern Virginia
2020 Bullitt, 2017 Tundra TRDPRO, 1976 Porsche 912, 1989 Porsche 944S2
The only way a hubcentric spacer will fail is if they are not torqued properly, and never checked thereafter.
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
... With either a stock spring setup ... I find the Mustang has a serious lack of front support and entry stability is not good. ... To make a front engine GT car turn, you need to be able to carry the brakes into the corner to keep tire load forward in the car...
My advice? Put on a big front spring, either the Steeda or BMR, without stiffening the rear spring. You don't can't afford to give up any grip on the rear of the car. A cheap and easy way to see if my advice has any merit is to put a 70 or 80 hardness spring rubber in the front and try it. https://www.resuspension.com/springs/spring-rubbers/res-5-00-spring-rubber-re-sr500-1500-xx.html
The Mach 1 is the first stock S550 to even go in the direction I'm talking about & it gets pretty good feedback from the track.
So there's a lot to chew on. See if it does anything for you.
@TeeLew, I have 2019 PP1 Magneride, and GT350R bars front & rear. I am unsure of the OEM spring rates. The spreadsheet in the 6g sticky thread is getting rather dated. If it is correct for my car then I am at only 165#/inch front rate, and 728 rear.
The M1 owner's manual publishes (page 339) 211#/in front and 742 rear for the handling package. So the rear is already pretty close between the two cars.
I switch several things converting my car from street to track and back again. So inserting spring rubber donuts would be easy enough to add.
Which hardness donut do you recommend for me to attempt to mimic the M1 front spring rate? Which sets if I ordered two pairs of different hardness?
Would be nice if there was a chart to help choose which donuts.
kz
West Chester, OH
Mustangs & F150
How did you come up with that ? I haven't looked (which should be easy to do) but dampers are probably exactly the same, VDM programming might be slightly different.
TeeLew
So Cal
Tim
Beauty might only be skin deep, but it's a reasonable indicator for overall prep.
TeeLew
So Cal
Tim
I do think that Ford Performance Track kit is a little better combo for spring rates. I don't know which MR dampers are on the M1. There is a higher damping force model which was on GT350R's and GT500's. It might have those.
