Gen 3 coyote Mustang, engine problems overheating
mike8400
el salvador
miguel
2019 mustang gt
Hey so I have fiends car that give maintance, a gen3 coyote mustang 2019 and we are having some problems and wanna ask if someone here has ever have this problem.
The car temperature while you cruise o have normal drive it’s always good between 195 en 208 f but as soon you give WOT the car raise the temperature crazy, up to 250 f (coolant temp) we have a Ford performance coolant pump, new thermostat, mishimoto 3 way pass aluminum radiator everything and the temperature raise really quick and that high, no problems on the coolant no extra pressure on the hoses no smoke nothing.
After that we check the cylinders with a camera and we saw this on the pictures that I attached
It will be very helpful I you can give me an idea of what can be causing that
BrakeFade
DFW, TX
E39 M5, '21 CFTP GT500
You sure you got all the air out of the system? Using 50/50 mixture of coolant and distilled water?
Timbuck
Tim
2017 s550 6r80
Those cylinders look kind of dry , patchy and rusted ?
how do each cylinder look on a compression test ??
are you running E85 ??
also are you sure both fans are operating correctly ??
engineermike
La
2018 GTPP A10
Cylinder head temp
The CHT is a temp sensor directly on the metal of the cylinder head. The metal temp reacts to load changes much quicker than water temp. What you're seeing might be normal. I'd log ECT just to see what the PCM thinks it's doing as a result of the CHT changes.
Skye
≈39N
"Skye" Mach1 N2144
In processing the marks on the cylinder walls...
Car is a 2019. Does this engine have a history of repair? Cylinder heads off? Pistons removed? Prior internal mechanical failure and damage?
I don't know what I'm looking at, the "splash" marks on the cylinder walls. I feel like the engine block has seen some prior damage. Either the original engine has been rebuilt, or this block is a donor from another vehicle.
WItoTX
Houston
Kyle
Is there an actual sensor for the coolant? Or is that value calculated from a bunch of different parameters like the "oil temperature" value.
Correct. I think Kevin (Honeybadger) did some videos on actual temps vs calculated temps. Might have been someone else. But the data is out there somewhere.
engineermike
La
2018 GTPP A10
ECT is calculated, but the numbers should line up better to what you expect. If comparing CHT to traditional ECT it won’t line up.
