FORScan Codes - S550 Mustangs
EastTNMustang
EastTNMustang
Knoxville, TN
2017 Roush Stage 3
jackieboy8
Netherlands / Santa Barbara
Jack
Mustang Convertible V6
Can someone add the changes that have to be made to enable the rear fog light indicator on the dash when retrofitting a rear fog light. (should be the same as enabling the pony side projectors using the rear fog light switch button)
comm
EU
Vaclav
GT350
Hi guys,
since I have a Canadian GT350 which has front tribar LED DRL working in low beam (high beam is only while park. brake is engaged) I would like to change settings with Forscan and have them in high beam all the time, but I don't know which settings exactly. Has anyone from Canada tried it? :)
Thanks.
buzz-dee
Germany
15 GT Premium PP
It's three steps
in the BCM you have to change
726-28-01 xxxx x*xx xxxx Rear Fog Enable Cfg: 0=disabled --> 1=enabled
726-24-01 xxxx xxxx *xxx Interior Lighting (IL) / White Lighting (WL) / Backlighting LED (BL) / Rear Fog Lamp (RFL) - Circuit DTC (Normal/Inhibited): 5=IL norm, WL inhib, BL norm, RFL inhib --> 4=IL norm, WL inhib, BL norm, RFL norm
and in the IPC
720-02-02 xxx* xx Rear Fog Indicator Cfg: 0=disabled --> 2=enabled
The first two enable the BCM output to the fog light, while the last one enables the indicator in the dash.
You’d still need a new light switch (with the button for the rear fog) and you need to add the terminals and wiring from the switch to the BCM and from the BCM to the rear fog light itself.
All credit goes to [MENTION=31524]Falk03[/MENTION] who made a really nice write up on the German mustang6.de forum
Chuck
Melbourne FL
2017 GT PP
How do I edit the "ABS" module? It does not show up where the other as-built data is. I am trying to enable drive modes on base>>sync 3 swapped vehicle.
Spart
Midwest
17 GT350
What adapter are you using to connect to the car? Does it have a switch on it?
Chuck
Melbourne FL
2017 GT PP
Spart
Midwest
17 GT350
Chuck
Melbourne FL
2017 GT PP
I was able to make a ton of changes last night just not under that specific ABS module. Don't think it's the OBD2 but I'll mess with it more
Spart
Midwest
17 GT350
No, that makes complete sense. Certain modules are HS CAN and others are MS CAN, which is why your device needs the switch in the first place.
And that's also why the auto-switching on the ODBLink MX Bluetooth is so nice.
Chuck
Melbourne FL
2017 GT PP
I ended up ordering the bluetooth one you suggested. We will see if that solves my issues. Thanks!
Chuck
Melbourne FL
2017 GT PP
On another note, I saw in your other thread that you set the theme to night mode at all times for the black background. How did you go about doing that?
Spart
Midwest
17 GT350
It's in the normal Sync 3 settings for the screen, under Display I think.
Might be too dim for some during full sunlight, but I prefer it to be unobtrusive.
I agree 100% with setting the SYNC3 display to black w/white lettering instead of the very bright white/blue default display setting.
Spart
Midwest
17 GT350
In the full time night mode, I just wish they'd allow you the full range of brightness. You can see it briefly go to full bright and then back down when you switch back and forth.
