Ford Performance Tune for 2018+ GT
bootlegger
Enginerd
Mount Pleasant, SC
James
Ex 2008 Mustang GT Owner
Suspension and tire makes the traction alot more controllable and the power much more usable. Agreed e completely transforms this platform.
I already have dual rate Steeda springs and I am running RE-71R 285s on lighter/wider wheels. I still need to finish buying stop the hop components, but I haven't found hop to be much of an issue after new wheels/tires/springs.
IrishStallion
Missouri
18 gt mustang
E85 tuned pulls strong even in heat and humidity. I notice almost zero power loss except traction is finally better. Car feels faster in the heat. Pump gas sucks. lol.
AZ18yote
Arizona
Bryan
Better rubber, springs and cradle lockouts are really key in hop control. Everything else is just a bonus.
AZ18yote
Arizona
Bryan
Cooler operating temps also just a nice side effect. Even in 110 avg summer temps here in Phoenix lol.
Davefzr
Glendora, CA
2018 mustang gt
So looking at your 1st graph vs. this recent graph. If i am looking at it all right, you picked up 20 peak hp and about 8 tq with the ford perf pack?
Overall, How do you like it?
The car feels amazing.
The best way that I can describe it is Do you know how the car feels amazing when it’s cold out? My car feels that way all the time even when it’s warm plus a step above that. I’ll be posting one more dyno sheet of the true before and after including the higher octane.
Pandajoshy
Virginia
Josh
2020 Mustang GT
I came across this video on youtube, someone got only 5+ HP and 7+ TQ on dyno after the install.
That's my video actually lol. Yeah that dyno run was right after install. I wonder if I dynoed it now maybe I would have higher numbers now that the car had time to learn the fuel octane?
Mustangpursuit
California
Mustang GT/CS 2019
I know in some cases some power installs dyno better over time not right away. Also KAM resets first may help and drive for maybe 500+ miles?
bootlegger
Enginerd
Mount Pleasant, SC
James
I am probably going Sport Cup 2s after I melt the RE-71Rs down. I really don't want to go much wider, as I want to keep this 285 square setup for handling.
Lbj
Washington court House OH
Larry
2019 mustang GT. A10 auto
So .... what is KAM and how do we reset it with a handheld unit or in the settings of the car..?
AZ18yote
Arizona
Bryan
KAM = Keep Alive Memory
Stores short term and learned values such as fuel trims. Can be reset using most handheld tuning devices, or manually by disconnecting negative battery terminal for at least 30 min.
IrishStallion
Missouri
18 gt mustang
Yeah takes 20 seconds with a handheld. I find my a10 picks up rough down shifts coming to a stop if I do not do a KAM reset occasionally. After reset car drives super smooth for a few key cycles until the tcu picks up it’s bad habits again. fyi.
Never bothered my tuner to try and tune it out completely...
AZ18yote
Arizona
Bryan
Yup can clear weirdness. Also great if you got lower quality fuel or something. Comes in handy if running a flex tune and wanting to relearn faster with higher e content. Like if I run 3 tanks of e54 then swap to a full e85-e90 for a track or dyno day etc, just one example of usefulness.
I recall back on the stock Ford tune an occasional surge on the a10 4-5 shift when still rather cold. KAM reset would kill that too.
IrishStallion
Missouri
18 gt mustang
Yeah these A10’s take a little patience and forgiveness in the end. If they did not run so damn good I would have flipped this car a long time ago. Reality is no car is perfect in every way.
AZ18yote
Arizona
Bryan
Facts. But pros far outweigh cons imo. A10 on e is a beast, though totally understand those that like rowing gears for the enjoyment, or for those where e simply isn't available.
