ESS G2 Start Up Issue - 2015 Mustang GT
jjdelicious
new york
2015 Mustang Gt Premium
Pulley Diameter:6PK 120mm (8PSI)
Intercooler Size:Standard G2
Volute color:Satin (standard)
Blow Off Valve:Tial Q50 2psi
Fuel Injectors:ID1050-XDS
Fuel Pump:DW415 with S550 install kit
Model year:15-16 (Gen.2)
Pump Booster:Vortech MaxFlow FPB
Supercharger Gear Type:High Precision Straight
2015 Mustang GT Premium AUTOMATIC
Hi all,
I’ve just installed my G2 Kit, my tuner sent me a million files for a base tune, every single file did not work. The car would start and then immediately die. Going to like 1k rpms.
i’ve swapped out to stock injectors, started it with stock tune and still does the same thing.
all vacuum lines and hoses are connected. I’m at a loss.
Goterr0r
St. Louis
Chad
2022 Mach 1
Who is your tuner? You shouldn't need a million base files with someone that is competent with the ESS platform. It took 1 single file to get mine dialed in. No changes needed.
jjdelicious
new york
Local tuner from Long Island
I’m just trying to understand to see if I made any mistakes
Goterr0r
St. Louis
Chad
2022 Mach 1
Reach out to Wengard https://wengerdperformance.com/ He is the go to for tuning these ESS kits. He may even help you troubleshoot before you would purchase a tune from him. He gives that kind of service. His tunes are pretty spot on.
daSNAK3
Cary, IL
Jake
2021 GT
Can you hear the fuel pump priming?… possible you got a bad one out of the box.
SheepDog
Colorado
Dax
Is you MAF tube backwards?
robvas
MI
2011 GT
Any codes? Post a datalog
does it idle with the throttle pressed?
SheepDog
Colorado
Dax
You should probably start with a reputable tuner and go from there.
Vacuum leaks (if not the tune) can cause your symptoms
Also, the injector data for the ID1050XDS is not the same as the ID1050X, but Im sure your "tooner" already knows that
Pistol_91
Clearwater
2020 mustang GT
This... When I tried inputting the values from the XDS sheets into the tune, the values were too high to be accepted. I had to use the X data sheet. If he fudged the XDS values into the tune. It won't work. Need to use the X sheet.
FWIW a completely stock tune file with correct injector data will start up and idle with the ESS blower.
SnowFox
Mn
Grabber
2022 GT, 2017 ECOboost, Saleen S351
Well the only thing that sticks out to me as weird is the many many tune files you received.
You should receive 1 start up file. Maybe a second if a revision is needed.
robvas
MI
2011 GT
If it doesn't start on the stock file with stock injectors, something was forgotten in the install
Justgonna send it
NC
Ty
2019 GT 6spd ess G3 kit 120mm pulley , wendgerd tune & 2020 hpp eco
When it comes to tuning ess kits
@Wengerd Performance OR Lund racing are top tiers.
Trust me on this. Buy cheap buy twice.
