Engine Differences of the 350R
honeybadger
Just don't care
COTA
Kevin
'17 GT350
  1. Of interesting note, the GR3Z part runs about double the cost of the FR3Z part through Whitebearlake ($166 vs $78)
svttim
Wisconsin
2019 GT350R
Checked with a Friend who verified with someone who knows, the GT350/R engines are physically the same with different calibrations
cosmo
Michigan
2005 Mustang GT
Too early to make that call. Let's see if we get a picture of the R phaser. There's evidence of a GR3E phaser existing with ties to the GT350R in an internal Ford system, and we know of a FR3E part physicaslly coming out of a GT350.
svttim
Wisconsin
2019 GT350R
Until proven otherwise, going to believe my contact from Ford. Not saying he cant be wrong just not very likley
Hack
Minneapolis
Mustang, Challenger
There are multiple confirmations in this thread that they use the same parts. But hey, if you are up for doing more checks, by all means have at it.
btown93
Earth
Knight Industries 2000
You don't find it significant that the Bill of Materials shows different part numbers for 2 different VIN numbers?
Hack
Minneapolis
Mustang, Challenger
1FATP8JZXH5526239 gt350r on ebay
Ford parts catalog shows BR3Z 6500 A for lash adjusters and FR3Z 6C525 B for phasers
Ford HVBOM (bill of materials) shows GR3Z 6500 A and GR3Z 6C525 B
I think Mr Turner has good information.
Non R vin shows BR3Z 6500 A and FR3Z 6C525 B in catalog and in HVBOM
I see what you are saying - there are 4 bills of material listed and 1 of the 4 shows a different PN. I missed that before. I just saw the three that were all the same.
cosmo
Michigan
2005 Mustang GT
Yes, that finding is what makes me believe there is something here.
Whether or not it is significant, I don't really care. I am just trying to get to the bottom of whether or not the GT350 and GT350R engines are identical or not.
btown93
Earth
It's certainly compelling evidence especially since it lines up with the article written by Editor Turner.
btown93
Earth
Some were using the ford parts catalog as confirmation that the part numbers were the same for R and non R. Most of the time catalog is accurate. From time to time, in the parts world you have to check whats called HVBOM (Historical Vehicle Bill of Material) in the event of a discrepancy. Until someone actually pulls the parts out the engines in question, we won't know for sure. It's interesting to me that this corroborates the article.
JAJ
Vancouver BC
2016 GT350 Track Pack
So, hiding in plain sight on the FP website, there's this:
M-6004-A50R
Variable Cam Timing (VCT) phasers require proper oil pressure to function correctly. It is inherent that all cam phasers have a certain oil leak rate. These high-performance cam phasers have a much lower leak rate than stock, allowing better control of the phasers at higher engine speeds and loads. These cam phasers are oriented for racing applications.
  • Fits 2015-2017 Mustang GT 5.0L
  • Original equipment on 2017-2018 Mustang GT350 5.2L
  • Includes 2 intake cam phasers
  • Includes 2 exhaust cam phasers
Note that it doesn't say that they were OE on 2016 or 2015 GT350's. So there was a running change in 2017, although HB's 2017 came with the older ones.
The problem that the original ones could create would show up as a cam timing error, which might throw a code and put the engine into limp mode. Some early cars did that, and this could be why. But it couldn't lead to damaged engines or high oil consumption, so, while it's interesting, it's not significant.
GT350-H6088
Mustang with a Mouth
Independent Hill, VA
Scott
2017 Shelby GT350 (H6088) RR Black stripes/white p
I disagree, evidence is too strong here. In other pictures in the article, you can see the stamping at angles which would be too obnoxious to Photoshop.
https://www.fordnxt.com/tech-storie...ms-build-the-shelby-gt350s-voodoo-5-2-engine/
The stampings have a different depth with the X's and the GR3E part number, that's why they look different. They're done at a different facility with a different tool.
Also, we have a forum member here who was genuine enough to post his photo of a confirmed GT350 phaser. Two different GT350 engines (a GT350 and a GT350R) with different parts. This also explains the difference in base part numbers between the GT350 and GT350R.
Do we actually have a picture of a GT350R phaser? the one from the artical may not be an "R" engine we don't know. Like Dominator961 said, "fake news"
What are the part numbers for the two motors?
The Engine ID Tags only show build date (intended as a serial number), Plant code, and the Calibration code.
My contact at ford says there is no difference in the two engines, the "R" has some different calibrations due to rotational weight reduction and
the removal of the resonators, these calibrations are very minor and mostly are emissions related.
cosmo
Michigan
2005 Mustang GT
Engine tag doesn't show calibration code, that's incorrect. The calibration code, if it was on a sticker, would be on the PCM where the calibration is loaded. The operators don't look at the engine code sticker to see what calibration they load, they push a button which loads the calibration based on the VIN which has other items tied to it apart from just the engine. What's on the label is the engine code (the part number of the engine) itself.
We have internal Ford BOMs showing a different part number for each engine leading credence to them being different. And a Ford contact saying all GT350s come with the GR3E which we know is false now, leading me to believe "inside sources" don't know what they're talking about.
