mustang_lurkers
- Feb 10, 2015
- Middle Of The Ocean Somewhere
- 2016 Shelby GT 350 Tech Package
I think the R sits slightly lower too.
I'm probably just being a little too anal. A flat board (splitter) parallel to the ground does not produce down force. They probably have shapes in the body pan behind the splitter (under the car) that actually produce down force, and they are counting them as part of the splitter. Maybe the other shapes in the nose of the car above the splitter produce down force, I don't know. Or possibly the nose of the splitter is aimed downward, serving as a spoiler as well as a splitter, but they are still calling it a splitter anyway. I'm sure there's down force and I'm sure whatever the engineer is saying is correct.The Ford engineer uses the word downforce an awful lot during his portion of the GT350 info video. Even talks about the splitter serving the purpose of "sucking" the car down, as you noted, plus adding downforce...
As long as the car has a nose, yes even a flat board will produce downforce. By 'splitting' the air you create a high pressure area above the plate and that air has to move some place. So yes it will indeed make downforce. Installing this at an increased angle or increasing the length in front of the tires will also increase downforce.I'm probably just being a little too anal. A flat board (splitter) parallel to the ground does not produce down force. They probably have shapes in the body pan behind the splitter (under the car) that actually produce down force, and they are counting them as part of the splitter. Maybe the other shapes in the nose of the car above the splitter produce down force, I don't know. Or possibly the nose of the splitter is aimed downward, serving as a spoiler as well as a splitter, but they are still calling it a splitter anyway. I'm sure there's down force and I'm sure whatever the engineer is saying is correct.
Of course the rear wing produces down force, that makes sense.
Good explanation and I had it wrong. Duh, yes of course there's a high pressure area at the nose of the car - and the splitter prevents some of that high pressure air from getting under the car. So it makes a boundary between two different pressures and creates down force.As long as the car has a nose, yes even a flat board will produce downforce. By 'splitting' the air you create a high pressure area above the plate and that air has to move some place. So yes it will indeed make downforce. Installing this at an increased angle or increasing the length in front of the tires will also increase downforce.
Your both kind of wrong. High air speed is low pressure air Bernoulli's Principle. By limiting the amount of air going under the car the speed of the air increases lowering the pressure under the car causing the car to be pushed from above into the lower pressure air below. The tunnels in the back also speed up the air under the car allowing the air in front to rush rearwards speeding up the air. Amazing how many people still don't understand how aero works. High speed air lower pressure, low speed air higher pressure.
