2018 GT350R vs 2019+ GT350R engine differences
MegaLoL
Poland
GT350R
Hi,
I need to change an engine in my 2019 R. I can get used one 2018 R with 1200 miles or obviously new one from the delaer. Is there any diiferences beside block from GT500? Any durbality, longevity etc?
I tried to search and read varied topics but could not find clear answer. I'm asking about R models only. I know that there were a differences in engine between regular GT350 and R before facelift in 2019 but how about let's say 2016 R vs 2020 R?
Tomster
Beware of idiots
Tom
Hi,
Are you hard tracking your car?
Inthehighdesert
NM
Charlie
What’s the reason for needing the replacement? I would not put a sub year engine in the car.
Tomster
Beware of idiots
Tom
Occasionaly i will visit Nurburgring 🙂 And maybe few regular tracks.
Then it would depend on the deal you are getting on the 2018 engine. If it was a deal, I would buy it, and then do a refresh on it and do some upgrades. If you are not pushing the car hard, I might just plop it in and be done with it. If you go the dealer route out of warranty, its going to cost a lot of money.
Tomster
Beware of idiots
Tom
He could keep the old engine, do a refresh on it, and be able to go back and forth as needed.
That's what I would do.
MegaLoL
Poland
GT350R
I had a front minor damaged but car ran without oil. Better to change all engine than repair.
MegaLoL
Poland
GT350R
2018 its a 7k cheaper than from a dealer.
What do you mean by refresh? And some uprgrades.
Tomster
Beware of idiots
Tom
no on the upgrades. Partial teardown to replace rings, valve components, maybe pistons, etc. A thorough refresh on an engine would run about 10K and you would be better off than a brand new engine. @honeybadger has been down this road frequently. I believe he told me a light refresh would run about $5K, a more thorough refresh about $10K, and if you want to go full on nuts with it, the sky is the limit.
As an alternative, you can just do a rebuild on the engine you have now and those prices (if they are still valid) would be applicable. Rebuilding the current engine would be dependent on its condition. Obviously a cracked block or major damage is not applicable.
Tomster
Beware of idiots
Tom
Nah, he had a viscious run in with a Camarah leaving Costco. Had to win that battle.
If it was a 5.0 coyote engine, I would offer different advice. You could pick them up at the junkyard all day long.
svttim
Wisconsin
2019 GT350R
There are some differences between the 18 and the 19 although not as many as the pre 18 base engine. Honestly, Id rebuild the original
Inthehighdesert
NM
Charlie
Can you elaborate on that? Is the block screwed like Tomster brought up? Was it running, lost oil, and seized? I can see more of an issue with your location and availability of parts then if it can be brought back to standard.
MegaLoL
Poland
GT350R
I see. Thanks for an explanation. It’s a major damge so new engine required. So no need to go after new one from the dealer and be short around 7k
MegaLoL
Poland
GT350R
Original cant be rebuild. I mean it can but it’s pointless.
