EB vs GT Summertime Powerloss
boB
boB
2019 GT PP1
Nope.
At any given temperature and pressure pair, dry air contains a higher partial pressure of oxygen than humid air, as with humid air the water vapor in the air exerts its own partial pressure, decreasing the absolute percentage and partial pressures of all other gases.
With respect to aircraft taking off, humidity increases the density altitude notably, lowering effective lift on humid days. Therefore, it is easier for a plane to take off from any particular location on a hot / dry day than it is on a hot / humid day at the same location.
There's a calculator for showing the effect of humidity on air density and density altitude here: https://wahiduddin.net/calc/calc_da.htm
Yes, but...
" Both an increase in the temperature and a decrease in the atmospheric pressure, and, *to a much lesser degree*, an increase in the humidity, will cause an increase in the density altitude. "
And then there is the effect of humidity on IC engines, almost like free water injection it lowers the temperature and allows more spark advance and more power.
vdin
NV
2017 Mustang GT 6mt
I live in the desert so DA goes up to 7500ft in the summer and the power loss is crazy, almost feels like I’m driving an Accord.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
It's probably an octane/knock issue and not necessarily the DA. My car on the dyno put down 400 to the wheels at 6000ft DA, but it wasn't that hot out so it was able to run max timing. With low air density plus a lot of timing retard, it's probably like driving a dog with zero throttle response. What are your CHT's like in the summer?
vdin
NV
2017 Mustang GT 6mt
It’s roughly around 215F when I’m cruising. It definitely could be knocking, I only have access to 91 octane here on the west coast.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Do you have the performance pack? I only ask because the radiator is about 30% larger on that and gives you some extra margin in hot temps.
Zooks527
2019 KB GT, 401A, 6MT, PP1, S&S, MR, AE, B&O / 2018 Jeep Grand Cherokee Summit
Yes, but...
Sure, but the comment I was responding to stated that "hot and dry" was worse than "hot and humid", so for that comparison one would have assume that both were at the same temperature and pressure, where humidity would be the only variable acting on DA. In that case, increasing humidity would increase the DA.
I'm not sure it does in this case.
You won't get the cooling effect, as that's a function of the energy required to evaporate the water after it's added to the intake charge. That doesn't happen in the case of changing humidity, as the water has already evaporated and is already in vapor form before the intake. You therefore don't get the concurrent increase in charge density that results in more oxygen being available for combustion.
WRT more spark advance, increasing humidity at any temperature results in a lower percentage of oxygen in the air (richening the mix for any fixed fuel flow) as well as reducing the density of the charge (also richening the mix at any given fuel flow). As the ECU's response in both cases will be to lower fuel flow to maintain its desired mixture regardless of timing, I would think a lower power output would be the result.
boB
boB
2019 GT PP1
Yeah, I don't know enough about the process to know if the relation between temp and humidity skews one way or the other but as you note, more humidity does increase DA. I recall living in Phoenix and at 118 degrees many flights were delayed until the temp dropped "but it's a dry heat...". ;)
As for the cooling effect of humidity I am not certain about that either, I recall reading about it in a book by Julius Mackerle, he was a specialist on air-cooled engines and that may change how it works. Anyway, where I live it is usually hot and humid so I am probably down on power most of the time. :(
Zooks527
It's 85 degrees in my back yard as I type this. I can't imagine adding another 33 degrees. dry or not !
There is absolutely a difference as increasing humidity increases the heat capacity of air at any specific temperature, meaning that a set volume of air is able to absorb more energy per degree of temperature rise.
That being said, the effect is pretty small (perhaps a couple of percent increase in heat capacity going from dry to saturated at normal outside temperatures) and it would be a trick to actually notice the difference.
Jaymar
Portland, OR
Jaymar
2022 GT/CS - Rapid Red
Driving a turbo car now I feel like it takes more of a hot day penalty than any NA motor I had before. Yes the turbo can make up for the lack of air density but the performance of that is limited by the intercooler which is also limited by the hot air.
Altitude, much like in aviation motors as mentioned, is far less detrimental. Taking my old 302 up into the mountains made it feel incredibly sluggish and this car barely noticed.
Garfy
Utah
Gary
2020 Mustang GT, 2012 Honda Fit Sport
Ding, ding, ding…. We have a winnnnnnaaaaah!
Open element CAIs are not beneficial on vehicles where they don’t see constant maintained speeds (Highway use), sit in traffic or are only driven short distances.
There’s been many facts posted about this across many auto forums, it’s nothing new. Even on this site alone it’s been proven that a closed airbox on a N/A S550 being used for daily driving in dense traffic has more benefits.
You might as well just call an open element CAI a HAI, because that’s exactly what it does… it sucks hot air building up under the hood right into the intake due to overwhelming heat soak. Heat soak is worse in spring/summer months due to higher exterior temps and far worse if the vehicle sits in stop/go traffic.
A vehicle with an open element CAI only benefits from it when and if the vehicle is used in a track environment, on highways or open rural roads where the vehicle is constantly moving and the air is cooled due to maintained speeds.
Yeah, most of the so-called CAI systems I've seen for newer cars are all drawing air from underhood. I recall some years ago (don't recall what kind of cars, maybe some 4-banger imports?) that had a system where they used a low restriction filter element but it was in a housing that included an air duct that ran out to the front of the vehicle, either through the grill or just under the bumper area. That was truly drawing ambient temp air into the engine, not hot underhood air. I wondered if it might have helped when you were at highway speeds in that the air was being pushed into the intake as well.
gadgtfreek
Fairhope, AL
Jason
2021 GT Premium Shadow Black 10spd Auto
Thats why I bought a CAI with a lid. Those "seal against the hood" things or open-air cones are dumb. They all get some heat, but why seal against the hot ass hood, or have an open cone for engine heat. Did anyone pop the hood on a 5.0 after driving for 15 minutes? You can fry and egg on it.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
I'm sure many learned the hard way by grabbing the prop rod with a bare hand, lmao.
gadgtfreek
Fairhope, AL
Jason
It's a hot sum-bit LMAO. You will only do it once...
NoVaGT
Northern Virginia
2019 PP1 GT Kona
Yes, but...
None of this means anything to the amount of power an ICE can create, in relation to humid atmosphere versus dry atmosphere. Humidity means the atmosphere contains that much less oxygen.
Have you ever noticed you can't fucking breath on a hot and humid day? That's because there's no oxygen in the atmosphere, your lungs are sucking in atmosphere that's packed with humidity instead of the oxygen you need.
And the same thing applies to your engine.
Qcman17
Ottawa, Canada
Cam
2019 Mustang GT A10 Velocity Blue 301A
Actually first they were blinded by the tail light flash when locking the car and as they staggered around disoriented they grabbed the hot prop rod in the hopes of stabilizing themselves. :)
