Broken crankshaft
turnswrench
turnswrench
MN
Bowman
F-150, WK SRT
Looks like that’s an o ring. My pump has an o ring on it. Is there nothing that goes between the pump and the mounting flange? I just want to make sure I’m not missing anything that might affect pump preload
Not on mine
TGGT
TGGT
SoCal
2018 mustang gt
Got it running today! All I needed was that roller lifter for the di pump and she started right up. I was watching my oil pressure pid on my laptop and it was stuck at zero which of course had me concerned, but it turned out to be a glitch in the software. My dash read normal oil pressure and when I removed and reloaded the oil pressure pid on the vcm scanner it started reading. Anyway it runs great. No ticking like I was hearing when it wouldn’t start. I was super relieved
TRP45ACP
Houston, TX
2018 GT Premium Coupe, PP1, MT82, 401A
Congratulations!
DougS550
Fishers, Indiana
Doug
Wow, you missed a grenade their. Great to hear it is running great.
TGGT
TGGT
SoCal
2018 mustang gt
Car runs great, good oil pressure, but …. It does have a rattling noise that I can hear clear as day when I put my stethoscope on the crank support. I’m probably going to have to pull the support off. See if the noise is still there. Then I’ll start pulling belts and hopefully I find it before I’m staring at the timing cover. I will say I am somewhat second guessing my decision to go with mmr oil pump gears though pointing any fingers is premature at this point
DougS550
Fishers, Indiana
Doug
If you put your stethoscope on the bearing support housing and against the oil pump cover, and underneath check all your mains one at a time, then the timing cover top to bottom, you will be able to isolate exactly the location of the noise. Also, might recommend removing your oil filter and send off to have it annalized. Good luck and take your time.
TGGT
TGGT
SoCal
2018 mustang gt
So I googled mmr oil pump gear noise and the first thing that came up was a post from a guy with a s197 with the exact same noise I have and I came across numerous post from people with noises relating to mmr oil pump gears. Anyway I preemptively ordered a set of gears from boundry. I ran them in my old engine and they worked perfectly so I went with them again. Not looking forward to tearing it all apart again, but if that’s what I have to do than so be it. I just need this thing to be perfect. I changed the oil in it today and it looked perfect as did the filter. I didn’t cut the filter open and really I don’t have reason too at this point
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
I think I remember posts on here that the Boundry gears are not heat treated properly.
If I am wrong sorry.
Gregory347
LI, NY
Greg
2019 GT A10 PP1, 1987 Buick Grand National, 1985 Mustang
SolarFlare
S. Fla
2015 CO GT
I wonder if that’s the buddy of mine with a whipple s197…hmmm I remember his shit was rattling
TGGT
TGGT
SoCal
2018 mustang gt
I’m just going off of my previous experience with the boundry gears. Truth be told I wanted the Ford performance gears, but no one has them in stock
TRP45ACP
Houston, TX
I ordered some MMR gears a few months ago and the clearances were pretty large. I returned them for another set and the same issue. I went with the boundry and they were tighter in comparison. They have been fine, without any extra noise.
TGGT
TGGT
SoCal
2018 mustang gt
Yeah I’ve seen that before and just watched it again. No blame on the boundry gears and seeing that my engine was brand new the pump housing should be good. I did check for any available movement of the housing before I snugged down the bolts but near as I could tell it looked perfect
96gt4.6
Kansas
2017 GT Premium/A6, 2020 Explorer ST
