Accelatec Resonated X-Pipe With Active Exhaust
Rock50
Rock50
2021 Mach 1
It wasn't bad sounding. Probably will work well in your set up.
gameovergt
Kevin
Lake Asbury, FL (Jacksonville area).
Kevin
2022 Ford Mustang GT California Special (A10)
gameovergt
Kevin
Kevin
getting her back today. Cat's will be gone & Corsa on with the Acceletec. Super excited.
gameovergt
Kevin
Kevin
In
gameovergt
Kevin
Kevin
Most important, are you happy with the sound?
Didn't get car back yet. Shop had to get some terminals for new digital boost gauge. Been there since Monday. Ugg. Lol.
Toretto
Mississauga
2021 Mustang GT Iconic Silver
Agreed. Interested to know how it sounds with just this resonated X-pipe
gameovergt
Kevin
Kevin
Will post video when its ready. Shop is getting revised tune from Wengard as the new vacuum block is causing a high idle.
gameovergt
Kevin
Kevin
Got her back. Super quiet in cabin. Can't tell it has longtubes & no cats. Just supercharger whistle & Corsa. Super Sleeper.
steathv
Lynchburg, VA
2022 California Special
Used the Magnaflow muffler with dual inlet and outlets that CJ Pony parts used to use, in place of the resonator, fabbed up pipes from a defective x pipe and installed. Smoother tone, quieter than stock at cruise, less raspy, sounds more like the way Ford V8's used to sound. Pleased. This has 2.5 inch inlet and outlets and 3 inch inner perforated x-pipe with fiberglass packing. Was looking for something quieter at cruise
Leigh_bullitt
Spain
Mustang Bullitt
Got the Accelatec today. It looks exactly like the Gibson design with chamfered pipes in an X configuration inside an empty (no fiberglass) muffler like casing. The chamfers open towards the inlet side. In some ways, probably is more restrictive than stock resonator, but does give a very non restrictive way for one side to cross to the other. Here are some picks comparing the length to a Steeda H-pipe and from the inside using a scope. Still on the fence about cutting the stock resonator.
A look on the inside, at the cross section of the X from the inlet side.
Slightly away, up into one of the inlet sides.
Looking down into one of the inlet sides from the top.
A view from the inside, looking down from one of the outlet sides.
Hi
You mentioned cutting the stock resonator ?.
did you not have the steeda h pipe installed to begin with ?.
I have the steeda H pipe already installed and assumed I could just remove and add this resonator without any additional cutting ?.
is that the case ?.
Thanks
Rock50
Rock50
2021 Mach 1
Had the H pipe laying around from another car. Steeda uses band claps, but Accelatec doesn't. The half that the band clamp covered, will just slide into the expanded section. Should fit without any extra cutting.
slime_bullet
Louisiana
Brett
2015 Mustang GT
Does yours have a weird harmonic vibration sound coming from the suitcase? I just installed mine and it sounds like absolute dog sh/t. It's not drone, sounds more like the suitcase is completely hollow
gameovergt
Kevin
Kevin
No. Just a whoosh sound. Gotten lots of compliments on sound
Rock50
Rock50
2021 Mach 1
Like a metallic howling type sound? This is what I had on mine with otherwise stock system. It is all hollow with perforated piping inside after all. Brought more sound closer to the cabin.
