Abnormal Camshaft Wear
LunarS550
LunarS550
Michigan
Garrett
2016 GT P1X ProCharger
I'm a "while I'm in there" kind of person and would replace them all. Just a personal preference.
I'm not a mechanic. It may not be needed. It would help me sleep better at night. That's all.
I appreciate the help, thanks a ton 🫡
LunarS550
LunarS550
Michigan
Garrett
Just to triple check, is drivers side considered left or right.
daSNAK3
Cary, IL
Jake
2021 GT
If boosted why run 5w20?
HKusp
Hampton, Md.
Jason
This was my question - why 5w20? I thought boosted applications required 5w50?
Not necessarily a REQUIREMENT but it certainly is a big time recommendation.
  • Like
Reactions: VoR
LunarS550
LunarS550
Michigan
Garrett
I'd sleep better knowing why it happened. Replacing parts without finding and fixing the root cause would keep me awake...
Yeah I didn’t sleep too well last night. Considering sending it out to get refreshed and maybe sleeved.
Racin4ds
Ocala, FL
Donnie
2015 Mustang GT
Proof again that 5W20 is NOT thick enough to provide the boundary layer protection that is needed in these motors! and Proof again why Ford switched to 5W30 in all Coyotes with 5W50 spec'd for track use. You had both against you, 5W20 AND Junk Royal Purple oil! Hopefully you learned a lesson... ;)
Jaymar
Portland, OR
Jaymar
2022 GT/CS - Rapid Red
While I'm no fan of either, before everyone hops on that bandwagon ask yourself why only 1 rocker out of 32 is affected then?
furdfan2018
AZ
Mustang
5-30 is fine for NA, I would not be running 5-20 with a power adder, temps come up instantly under boost.
Ehhh... there is no "black and white" as it relates to which oil to run.
Way too many factors... climate? How hard is the car driven? How often? How many miles per year? How often does the oil get changed? Do you use any additives?
If I lived in a cold climate, rarely drove my car in boost, and changed the oil every 6 months regardless of mileage -- there is NO WAY you could get me to run 5w50. Absolutely not.
LunarS550
LunarS550
Michigan
Garrett
Yeah odd. I’m not going to jump to conclusions. Replacing what needs to be replaced and running 5w30 motorcraft
Yeah I’m in Michigan, 3k miles or so a year, 1 oil change per year. Probably going to run 5w30 motorcraft from now on.
Optimum Performance
Gold Sponsor
Titusville, Florida
www.facebook.com
Tommy
'15 GT PP
Oh, I'm not concerned about his current failure, that is simply a surface finish issue most likely. The rest of the motor of unknown history, tune, maintenance and use is why I wouldn't be running 5-20 in this car. The reason they go to 5-50 is because it causes less issue with the VVT control on track.
