TIRE WEAR
17MagMetal
San Francisco
Michael
17 Mustang GT, 07 Ford Taurus SE, 95 F250 Xlt
Hey everyone,
Washing car today for the first time in forever, took wheels off for cleaning and noticed after 13k the front Michelin PSS are wearing a little more aggressively on the inner shoulder tread block.
The car was set to have just the slightest bit of toe in and -1.6 negative camber on the front end.
The rear was set similarly and is wearing (seemingly) more evenly. I won’t feel bad about replacing them when the time comes. It would just really bug me to have to replace $900 in tires because of the inner shoulder (as I’ve seen in other posts!).
I’m very diligent about checking tire wear/tread depth, so i’m hoping I can get some advice on alignment specs to reduce some of this front inner shoulder wear. The rest of the tires have a ton of tread (7/32, inner shoulder is probably down to 3-4/32).
Is this an alignment problem? Did I just knock my alignment out? Do I need to turn harder and more often?
elChupacoffee
Canada
Ken
2017 Mustang GT PP
Don't know how true this is, but the guy I bought mine from told me that mustangs (or at least mine) comes with some negative camber from the factory, which I can only assume is for performance handling reasons.
17MagMetal
San Francisco
Michael
You’ve definitely heard correctly!
I have adjustable parts on the front and rear end camber adjustment. I think Ford specs base GTs to have something like .6-1.2 deg negative camber for the cars. I’m just trying to prolong some tire life for weekend cruising.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Check your toe, probably have some toe out
17MagMetal
San Francisco
Michael
I hope you’re right and my car just got knocked out of spec. I’ll have to go in for an alignment.
To your knowledge, toe IN should scrub the outer edge of the tire right?
Camber obviously wears the inner portion of the tire, but I’m seeing actual shoulder issues.
K4fxd
NKY
No, toe in and or out will wear the inner edge of the tires. Camber has little to no effect up to -2.5 or more.
17MagMetal
San Francisco
Michael
Hearing you say that brings me comfort for some reason, I’ll ask my favorite tech to do a two wheel and see if the toe got knocked out. I’ll bring it back to the .02 deg toe in if so.
Will report back!
K4fxd
NKY
Slight toe in helps take out steering slack and runs the tires straight when rolling. I like .05 each side of toe in and I run -2.25 camber each side. I get even wear but I do like to push corners once in awhile.
GJarrett
Bradenton, FL
Gerald
2017 EcoBoost Premium
Toe would be the first place I'd look, but I'm also thinking -1.6 camber is a little much for street camber and might be part of your inner wear if you are not driving seriously aggressive on the street. You could also consider dialing that back a tad while you're checking your toe in.
17MagMetal
San Francisco
Michael
Toe would be the first place I'd look, but I'm also thinking -1.6 camber is a little much for street camber and could be part of your inner wear if you are not driving seriously aggressive on the street.
Agreed!
I’ve got camber to tuck the GT350 wheels on my base GT, but otherwise like to drive 25-50% of the time spiritedly on the backroads.
i’ll have to see what the car is sitting at and make a decision.
17MagMetal
San Francisco
Michael
I’ve really enjoyed a less aggressive version of your alignment. My car on all four corners is like .03 toe in and -1.6 camber.
Rear ends wearing wonderfully, something must be awry up front.
K4fxd
NKY
It still plows like a dump truck. If I could live with the tramlining I'd go to -3 front camber.
17MagMetal
San Francisco
Michael
At least on road, my biggest challenge is oversteer still.
I’ve thrown all kinds of stuff at the car and can’t drive it at its true limit (on road with no risk). I should track it for repeatability and make the most of the adjustable bits on it.
edit: I also have BMRs adjustable bars set to their middle setting on both axles, I have considered dropping the rear setting to “soft” and seeing if I can reduce the oversteer I experience.
K4fxd
NKY
I can't use more than about 50% throttle on street curves without feeling like I'm being reckless. We do have several round-a-bouts but hitting them without other traffic is rare.
17MagMetal
San Francisco
Michael
You and me are on the same page, I feather every corner.
I’m young, naive, stupid, but not a moron, I know how dicey all RWD cars get :cwl:
