Upgrading to Sync 3.4
wade001
Central Florida
Wade
2019 GT Prem. 10r80, PP1, 401A, Active Exhaust
Like I said, I did follow instruction to the teeth. In my case I have incorrect license file and during the installation it through the Error Code: PKG_ERR03. I contacted Ford and they send me a link to direct download. Still it's downloading wrong license file. Enough said.
your license file (4U5T-14G424-CC.TAR) was the same name as mine..
i believe the pictures are just for an older install, or diff model car? but in any case, my license file was named the same, and mine eventually installed. after i had to contact them for support of course, but my fault there..
torque124
Torque
MA
Shelby GT350R
I spoke to Ford today and they told me to wait at least 48 hours before attempting again, as their service is actually down. There are too many users trying to download the new maps, and the database where the files are stored crashed.
I suppose all america has caused a DDOS attack on the servers trying to download maps the last few days .... :)
Bikeman315
Myrtle Beach, SC
Ira
OK, so one of two things. Yes you still have the wrong file. Having done this many time I can tell you that this is unlikely. It is more likely the file is in the wrong place. Did you copy the license file into the "Syncmyride" folder? Did you check for the parenthesis correction on page 6. These two things have screwed up a lot of folks.
Bikeman315
Myrtle Beach, SC
Ira
Thank you for that information. Maybe that's why the website is still telling me I already have 1.19 (I don't).
That said, I'd rather have a................
Bikeman315
Myrtle Beach, SC
Ira
around the 30-40 min mark it will say "update complete, blah blah blah.. remove USB drive" but its not actually complete.. it will display that message for 3 seconds or so before it reboots the entire system, then continues the update for another 10-20 min or so.
This pretty much tells you everything you need to know about Ford's SYNC updates.
torque124
Torque
MA
Shelby GT350R
The downloads are back online; I was able to download my maps today... Installing to the car soon. I had to pay 103 bucks or so again.... damn Ford.
wade001
Central Florida
Wade
does your "about sync" screen say version 1.19? what did it say before the update?
matthewr87
2018 GT350
Damn $103? Not sure if the map update is worth that much. Google maps via Android Auto is much better for actual navigation anyway.
torque124
Torque
MA
Shelby GT350R
I am getting an error LST_ERR05... which seems to be the license file missing... but it's not, it is in the SyncMyRide folder... I made a copy and had a look inside, it contains a certificate and a license.txt file. The license.txt file contains just a line of txt, the version, in my case: JR3T-14G421-CD
BUT , the parent license file has a different name: JR3T-14G424-CD.TAR.GZ.
Can someone please confirm what you have after a successful install; if license.txt file matches your parent archive license name?
Thanks
lenFeb
USofA
Len
2019 Shelby GT350 #K0110
Update went through(longer than 1 hour, system rebooted itself 2 or 3 times before I remove USB) said update completed, remove USB(I had this at least 2 times during the installation), update will take effect next time you enter the car. Before update I had maps version 1 17. After update and turning car off, exeting, locking, unlocking and entering starting the car, still 1 17. At this point I'm thinking the installation wasn't update at all.
Bikeman315
Myrtle Beach, SC
Ira
How long did this take. The full install take at least 60 minutes. I found when doing my 1.18 update that you were not supposed to pul the USB after the first notice.
Bit_the_Bullitt
Ohio, US
Richard
2019 Bullitt
Did you unzip all the files including maps and license files into USB?
Yes, did exactly what the instructions asked for, still nothing.
Customer service lady said it may take a couple of days to show and finish install, which makes no sense. The install was the 50min of idle (now for no reason) my car had to do...
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
Guys, it's not necessary to have the engine running. Wasting gas and the life of your car. Just make sure you have a healthy battery, turn off the headlights, or hook up a battery charger to be sure. Push the start button without starting. If the update gets interrupted press start again and keep doing it until finished, the data transfer from USB will resume if interrupted. I did my Sync update and my map update this way.
lenFeb
USofA
Len
I was driving my car while installation. The first system restart was at around 35-40 min mark. Then it took about 20 min for the second system restart. Then another 10 min for the third system restart and second time it said update competed and remove USB. All this time during the installation I never remove USB. Still nav maps version is 1 17. If you don't remove USB and the upgrade completed with the last restart, the upgrade will start from the beginning without saying that there is same version of maps in both Sync 3 and USB. This upgrade install shouldn't be that hard.
