Upgrading to Sync 3.4
Tank
9/11 - Never Forget
Above the Notches
G0853
Jim, didn’t the pre CP 2016 cars still have Sync 3. I thought it was a build update to get it.
The 2016 models with the smaller 4” screens had Sync w My Ford Touch.
Think Track, R, and Base.
Sync3 is only mentioned for the Tech here:
https://www.mustang6g.com/forums/th...re-at-your-own-risk.89612/page-4#post-2155026
My Tech came with the larger 8” screen and Sync 3 but not Software Version 3.0. from the factory, it did not support AA and CP.
I needed to swap out the USB in the console to get the system to accept Sync 3 ver 3.0- sounds crazy...
Just checked the Ford Owners site- apparently I can update to Sync3 ver3.0.20204. Might do it for giggles but I won’t expect anything earth shattering.
JAJ
Vancouver BC
2016 GT350 Track Pack
I appreciate all these comments on 2016 Sync3, but my 2016 Track Pack came with a 4" screen. I upgraded twice and it now has a 2018 electronics set - APIM, ACM, FCIM, USB Hub, etc. Oasis shows my car as equipped with this setup, so I get automatic WIFI OTA software updates and I can buy map updates from Ford's supplier as well. I'd give up Ford's support if I switched to 3.4 - in effect, I'd go from minimal support to none at all. And, in reading about 3.4, other than it perhaps running a bit faster, there didn't seem to be much difference for cars that don't have the big wide OLED dashboard.
So, as things stand, I'm on the latest 3.0 software with the latest maps. CarPlay and Android Auto both work great over a USB cable.
One of the drawbacks of installing all this updated kit in a car that was built with a 4" screen is that the climate controls don't work very well because the car is missing some sensors and actuators. So, I installed the missing sensors and actuators and climate control works great now and there are no DTC's on any of the car's systems.
milner_7
Hamilton Ontario
www.highdefinitionautodetail.ca
2016 Shelby GT350 Deep Impact Blue
Keep in mind that although the version hasn’t changed there have been many build updates over the years.
True but nothing of any real improvement.
milner_7
Hamilton Ontario
I didn't have to swap out the console usb and was able to upgrade to Sync 3.0, however if wanting Car play would have to change the usb. AA does work with the usb under the 8inch screen
Tank
9/11 - Never Forget
Above the Notches
G0853
It’s like you’re in a whole ‘nother country....
I never looked into the AA aspect - just wanted CP and I couldn’t get the upgrade without the USB.
its_me_walt
CNY
Walt
17 GT PP Vert
so i have a 2017 on 3.0.2024 software. am i able to cyanlabs it to 3.4 safely?
Bikeman315
Myrtle Beach, SC
Ira
I presume you got your screen working again? If the answer is yes, and you are out of warranty you can safely update using Cyanlabs. Just read, and reread the instructions and you'll be fine.
its_me_walt
CNY
Walt
17 GT PP Vert
cool man, thanks for all of your help. much appreciated!
its_me_walt
CNY
Walt
17 GT PP Vert
Getting “not enough space on disk” error trying to make thumb drive. Tried on 32 and 128gb. Gunna take it as a sign to stop for now
