Steeda Jack Rails - Install Questions
tj@steeda
Timothy
You won't be disappointed ... many customers have purchased/installed & the feedback has been tremendous.
Small investment for such a beneficial part:
http://www.steeda.com/steeda-s550-mustang-ultra-lite-chassis-jacking-rails-15-16-all-555-5205/
Product Benefits
-60% lighter than the competition, only 12 lbs
-Allows you to jack up your S550 anywhere along the jacking rail, preventing damage to -your factory pinch welds
-Open mounting bracket design prevents water from getting trapped and therefore eliminating chances of rust
-Will work with Steeda's popular IRS Subframe Support Braces
-Includes all necessary mounting hardware unlike the competition
-Lifetime warranty
-Made in the USA using high-grade materials
snaproll
Naples Florida
Bruce
350R/88LX/FR500S
Which ones are longer - steeds or bmr? Or are they within an inch of the same?
Epiphany
Global
I like to disassemble things.
BMR are quite a bit longer.
tj@steeda
Timothy
The Steeda units are 34.5” long.
Best Regards,
TJ
snaproll
Naples Florida
Bruce
350R/88LX/FR500S
16s550
Bay area
2016 GT M6 performance pack, whipple charged
I have a lot of steeda parts too. Seems like an easy fix/change for them. Not sure I see much downside for them to change it.
Those appear to be about the same length as the bmr. They look nice too.
I'm sure they are long enough and I'm sure they maybe did it to save weight. Mine just got here today:)
stanglife
Jeff
1993 Coyote Coupe
I liked the adjustment that BMR put in so that it was level with the ground. Installed mine in about 20 minutes with no jacks.
Epiphany
Global
BMR Jacking Rails...
If you look you can barely see them. They are an extremely robust design and allow for wide jack points/stands. They are exactly what I want from a jacking rail. The fact that the red color matches the car ain't bad either.:clap2:
Tank
9/11 - Never Forget
Above the Notches
G0853
tj@steeda
Timothy
We designed ours to be functional & have reduced weight - weight is the enemy of performance. Others have designed their units to be longer, etc.
Our units have balance & functionality:
Best Regards,
TJ
