J&M Products New Jacking Rails Now Available
rroese
San Luis Obispo Calif
www.hotpart.com
Bob
2015 Mustang, 1959 Thunderbird
2015 2016 Mustang Full Length Jacking Rails #25200 for the 2015-2016 Mustang is CNC laser cut and tig welded, utilizing a machined insert that gets welded into the rail to provide maximum strength and rigidity, the required new hardware is included. The insert is a machined from high strength carbon steel piece that gets tig welded and then the end caps get welded to keep out the road grime/weather preventing rusting and corrosion. No cutting drilling or other modifications are needed to install the new rails. Adds additional rigidity to the chassis, jack the entire side of the car from one convenient location.
Rails are designed to fully protect the rocker panels and the factory jacking points from damage when jacking up the sides of the car at the track, doing oil changes and during “off roading” protecting the factory pinch welds and rocker panels from damage/folding and collapsing.
Jacking Rails are available in either Red powder coat (25200R), Black powder coat (25200B) or for those that might want to paint them the same color as the car, a bare finish (25200).
2015-2016 Mustang Full Length Jacking Rails Part # 25200 features and benefits:
  • Protects pinch welds and floors
  • New hardware is included
  • No cutting, welding, or modifications needed
  • Installs in minutes
  • CNC laser cut and tig welded
  • Grade 10.9 hardware included
  • Unique machined metal insert for added strength and rigidity.
  • Made in the USA
J&M Products
hotpart.com
805-544-1128
[email protected]
HavasuCat
AZ
2015 GT Base, Competition Orange
Could you post pic's of them installed showing the mounting and the protrusion below the pinch points?
Thanks
rroese
www.hotpart.com
Bob
https://hotpart.com/wp-content/uploads/2016/06/Close-Up-Welded-Inserts.jpg
The jacking rails are mounted through the factory bolt hole locations at the front and rear of the rocker panel 2 front 2 rear we supply the new hardware. The bolts are recessed into the machined inserts that are welded into the rail.
https://hotpart.com/wp-content/uploads/2016/05/Jacking-Rail-Full-Length-Bare-Finish.jpg
The image above is a prototype rail that isn't our production length but it shows the rail mounted.
https://hotpart.com/wp-content/uploads/2016/08/20160817_081148.jpg
Here it shows the protrusion below the pinch weld.
Let me know if you have any other questions.
