Single top mount turbo - Supporting mods
NGOT8R
NGOT8R
Adrian
2019 Bullitt
Guess what just arrived? Man is this thing not only huge, it’s heavy! I’m definitely gonna be adding somewhere in the neighborhood of 130 lbs to the front of the car.
Timbuck
Tim
2017 s550 6r80
Very nice Christmas present to your self haha. What spec did you end up going with ?
HKusp
Hampton, Md.
Jason
The added power will more than make up for it. When I first put on the Whipple, I noticed a difference in the balance of the car, obviously, but after a little while, you get very used to it and the new way the car handles becomes very predictable.
NGOT8R
NGOT8R
Adrian
2019 Bullitt
It sure is! Initially, I had ordered the 80MM, but late last week, I learned that BL Fab was having an issue getting a part to complete the build for that turbo. They offered to upgrade me to the 88MM compressor free of charge, so that’s what I did. It has all the same specs (7+7 billet compressor wheel, billet thrust plate, 96MM T6 turbine and 1.32 A/R).
NGOT8R
NGOT8R
Adrian
2019 Bullitt
Okay, that’s good to know!! I was thinking that was gonna be an issue with the springs and Magneride struts.
Jwest989
AZ
JWest
2015 Mustang GT
Any updates? Would like to know how this turned out
NGOT8R
NGOT8R
Adrian
2019 Bullitt
No real updates at this point, other than having purchased almost everything on my parts list needed for the install. I’m still waiting on our house to be completed. We have about 4 months left in the build process and it seems like it’s taking forever. Once we get moved in, I’ll spend a few months dialing in the house and setting up my shop area and then I’ll get to work on the install.
Turbo Bullitt Parts
  • BLF Single Turbo Piping Kit (purchased)
  • Holley Low Ram Coyote IM (purchased)
  • Silicone Couplers w/T-bolts (purchased)
  • SS V-Band Clamps (purchased)
  • EbOOst2 Controller (purchased)
  • Radiator Fan Shroud (purchased)
  • Turbosmart Powerport BOV (purchased)
  • Dual Turbosmart 40MM Waste Gate (purchased)
  • BL Fabrications 3.5" Wiggins Style Clamp Throttle Body Adapter for Coyote (purchased)
  • Titanium T6 Turbo Flange Stud/Nut Kit (purchased)
  • Coolant/Catch Can Reservoir (purchased)
  • Intercooler (purchased)
  • BLF Turbo Unit (purchased)
  • Nitrous Outlet Wet Nozzle (purchased)
  • Delta Pag 14” Fan (purchased)
  • Turbosmart Turbo Oil Pressure Regulator/Filter (purchased)
  • Turbo Oil Feed/Drain Line Weld On Fittings (purchased)
  • Fluidampr Harmonic Damper 700232 (purchased)
  • Oil Pump Gears (purchased):
  • Valve Springs (purchased)
  • Valve Seals (purchased)
  • Valve Retainers (purchased)
  • ARP Head Stud Kit (purchased)
  • Deatschwerks X3 and 1500cc Injectors (purchased)
  • VaporWorx Returnless Fuel System PWM Controller
  • Davies Craig Electric Water Pump and Digital Controller (purchased)
  • Aluminum N2O Nozzle Bung (purchased)
  • 3.5” V-Band Gaskets (purchased)
  • ARP Timing Cover Bolt Kit
  • FoMoCo Camshaft Drive Kit
  • ARP Cam Cap Bolts (purchased)
  • Head Gaskets
  • FoMoCo Header Gaskets (purchased)
  • Exhaust Trim Ring (purchased)
  • Chew Motorsports Push Bar?
  • Vacuum Manifold (purchased)
  • Fat Fab Coolant Distribution Manifold (purchased)
  • Parachute Mount and Parachute
  • 6 Point Roll Bar
  • Miscellaneous Fittings and Hoses (purchased)
wingnutt
@FL410
michael
350R Procharged w/P1X
Sooooooo…next October then 😂
wingnutt
@FL410
michael
DougS550
Fishers, Indiana
Doug
I’ve made the decision that I will be adding a single turbo to my 2019 Bullitt. I would like to hear from the turbo folks, what supporting mods are mandatory to allow for a good margin of safety? I would also like to know how much power you guys are making on 93 and E85?
For the single turbo cars, did you guys have to do a wire tuck in the engine bay to keep they clear of the turbo headers. Thanks.
If it was me, unless I have spoken to actual mustang owners running top single mount turbos on the street to know the ups and downs for the single top turbo. Do you really want to be the R&D ginnea pig for some ones unperfected kit? Hard decision for sure. Good Luck
NGOT8R
NGOT8R
Adrian
2019 Bullitt
I’m committed now. The only thing I can think of is a good filter for the compressor housing. Many run a Turbo Guard, which I will do at the very least, but I would prefer to run a filter for the majority of street driving.
Fuel system upgrades is a whole other story. I know I will end up running a 3-4 pump PWM controller for my triple pump setup.
