SCCA CAM-C Thread
Dana Pants
Burlington MA
Dana
2018 GT PP1
And using a couple janky pieces of aluminum sheet pressing against a tire sidewall is a better way to set total toe? Gotcha.
bro. That’s not even how they work.
TeeLew
So Cal
Tim
You didn't go very stiff on the front spring and the HPP+HP includes a fairly stiff rear bar. If you go stiffer rear I'd pair with a GT PP or base GT bar (22.2, 21.7 mm vs your 24 mm).
Ya, when I was looking at the spring selection, these seemed like a reasonable step stiffer (~30%) and was about as low as dared drop it. Depending on how this goes I might take a stab at the 300# BMR's.
The rear bar is fairly big on this thing. The limited options kind of suck. I see a fab project and blades in my future.
TeeLew
So Cal
Tim
Brian@BMVK
Illinois
2015 GT - Sold
The 300# BMRs are not sold anymore, FYI. Also they did not fit properly, and either had too much free play at full droop (first version) or had too much drop (second version). The third version is 250#. I have a pair of the first version at home but never installed them.
TeeLew
So Cal
Tim
Have you ever loaded a stock-style spring with spring rubbers to stiffen it up? It would raise ride height also, but maybe an interesting test? As it was, the preload on these springs was nil. I just pushed them down with my hand to start the nut on the strut.
TeeLew
So Cal
Tim
Those plus some sort of spacer/helper setup might be of interest. How much do they rattle at full droop?
Brian@BMVK
Illinois
2015 GT - Sold
I never installed, but what I was told is there is about 1/2" or so of free play at full droop. To be honest taking that up with isolator/spacers would probably work well for rate/height.
Dana Pants
Burlington MA
Dana
2018 GT PP1
probably best handled with shortened struts. Bilsteins B8?
Dana Pants
Burlington MA
Dana
2018 GT PP1
In Volvo land people used to use huge metal zip ties to avoid that lowering springs fall out. I think it could be done for a Mustang as well if really needed.
TeeLew
So Cal
Tim
No one really *likes* doing things like that, but on track it works just fine.
TeeLew
So Cal
Tim
jpaulson
Portland, OR
2016 GTPP
Well, the GT is gone. I have drank the koolaid and bought an SS 1le to run in BS. Need to clear out the garage. Here are links to the for sale threads.
Megan/Bilstein coilovers:
https://www.mustang6g.com/forums/threads/megan-racing-bilstein-hybrid-coilovers.147516/
18x11 Apex EC7 with 295 30 18 A052:
https://www.mustang6g.com/forums/threads/apex-ec7-18x11-square-setup-w-295-a052.147518/
19x11 SVE with Re71R:
https://www.mustang6g.com/forums/threads/19x11-sve-square-setup-with-305-re71r.147519/
19x11 SVE 359R with Re71R:
https://www.mustang6g.com/forums/th...oss-black-square-setup-with-305-re71r.147520/
Brian@BMVK
Illinois
2015 GT - Sold
Good luck with it!
TeeLew
So Cal
Tim
I wish Bridgestone and Falken could swap price tags.
