SCCA CAM-C Thread
TeeLew
So Cal
Tim
I'm on a work trip right now, but one of my daughters sent me picks of the boxes showing up at home. The latest is the parts I ordered to build toe bars. I have a bunch of stuff for the front end of the car, but before I install that stuff, I need to be able to align the car afterwards. The last big outlay has been to build the parts which let me do alignments by myself.
o-man
Durham, NC
Oscar
2019 Ford Mustang Bullitt
https://tire.bridgestone.co.jp/potenza/re71rs/
TeeLaw, I’ve been with you on the Goodyear front for years. I finally broke down and bought the SC3, 305-30/19. Drove my first autocross today on them and was quite impressed by them. I run CAM-C in my Bullitt and have a good time with just springs, camber plates, and CB005. Good luck with your endeavor
TeeLew
So Cal
Tim
I got off my ass and did something today. I changed front springs, front bar, adjustable drop links, camber/caster plates, camber bolts and extended lugs. The car's back on the ground and I'll string it tomorrow.
TeeLew
So Cal
Tim
Played some yesterday, but didn't get it aligned yet due to a shortcoming with the alignment fixture design department. I'll take another stab at it today.
First thought, those extended wheel studs are a subtle, but effective, visual. I only put them on the front because that's where the wheels will have a spacer, but I'm going to have to match the rear. It has a 'no-bullshit' look to it that I like.
TeeLew
So Cal
Tim
Brian@BMVK
Illinois
2015 GT - Sold
Tenhulzen plates w/ integrated camber gauge is the easy way to align a car.
I have these plates and I'm honestly not a huge fan. There's so much variability from lots of points of deflection.
TeeLew
So Cal
Tim
My fixtures will need a Mk2 iteration to be really right, but it's a lot better system. They'll be open source for anyone here.
TeeLew
So Cal
Tim
I'm sitting at -3.3/-3.4 deg on front camber. Rear is pretty skinny at -0.6. I left the rear because I'm lazy. I'll take care of it after I get my front fixture built (when it's easier to set toe). I set front toe to 1mm in per side and the rear to 2mm in per side.
It drives nice and there's nothing that stands out as incorrect. I haven't gotten very frisky, yet, so I can't really comment on balance.
My stock front bar was marked '31' with a paint pen. The tag (& calipers) shows it's actually 33.3mm. The BMR one is 35mm. To be honest, I don't think that's much of a difference. It's not enough for me to tell just rolling around town. I started it at mid/mid settings.
The front springs are the Vogtland Sports. They're 220#/in. Honestly, they don't feel like a huge change, either. My old Fox a hundred years ago was significantly stiffer on the front. That's not necessarily good, it just was. Maybe the Magnaride is a bigger variable than the springs?
Anyway, over the last couple days, I feel like I've taken a nice step with the car prep. First event is late Sept, so I've still got a while. Energy Suspension is way behind on production, so who knows when I'm going to get to play with suspension bushings. At least I've got this part accomplished.
Brian@BMVK
Illinois
2015 GT - Sold
You'll need a lot more rear camber. With that much front I'd recommend -2.0 rear.
What do you mean by mid/mid? You're not running the BMR rear too, are you?
TeeLew
So Cal
Tim
I just went to pick up my daughter from work and got a chance to hustle a corner. Ya, I'm gonna need that camber! The front feels strong, but the rear can't keep up. It's definitely getting too much on the sidewall.
By mid/mid I meant I was in the middle adjustment hole on the both sides of the FARB. I didn't get the rear bar. I can see going quite a bit down from where it is.
My experiment is leaving the stock rear springs for the time being. This means I've got a good bit of rake in the car. Honestly, I don't feel like it's all that soft. I'm going to run it like this for a couple months before putting the stiffer rears in. It'll be an interesting learning experience. I'm going to keep an open mind & see which I prefer.
Dana Pants
Burlington MA
Dana
2018 GT PP1
Ya, the problem with using plates like these is getting the front & rear pointing in the same direction. I'll take some pictures of my lash-up when it's finished. It will look something like this: https://nasaspeed.news/toolshed-engineer/string-alignment/?amp
I use string to set thrust angle.
Because total toe is more important than thrust angle, it should be prioritized in the measurement system to minimize tolerance stack up.
Brian@BMVK
Illinois
2015 GT - Sold
You didn't go very stiff on the front spring and the HPP+HP includes a fairly stiff rear bar. If you go stiffer rear I'd pair with a GT PP or base GT bar (22.2, 21.7 mm vs your 24 mm).
TeeLew
So Cal
Tim
And using a couple janky pieces of aluminum sheet pressing against a tire sidewall is a better way to set total toe? Gotcha.
