BGunn
Hi Guys,
I wanted to start a thread specifically for setup on the 15 Ecoboost mustangs for the SCCA STP class.
Here is my setup (I will update as changes are made)
2015 Mustang Ecoboost 2.3L + 50th Year edition + Performance package
Currently I have the following alignment settings:
Front Camber = -3.0
Front Cast = 7.5
Total Front Toe = -0.10
Rear Camber = -2.0
Total Rear Toe = 0.10
Front sway bar settings = Middle
Rear sway bar settings = Middle
Front shock settings (32 way damping) = Middle, 16 clicks up from soft
Rear shock settings (32 way damping) = 5 clicks up from soft
Wheels
Mustang GT Black Track Pack Wheel: Part Number M-1007-DC199B
o 19"x9" wide
o 5-lug, 4.5" bolt circle
o 42mm offset
o 6.8" backspacing
o o 33.00 lb (s)
Tires
255/40ZR-19 BFGoodrich g-Force Rival 3-Rib Tread Design XL
Exhaust
Magnaflow 19191 Ford Mustang 2.3L (Competition Series) Performance Exhaust System
Engine
Cobb AccessPort , Tuned by Adam Brunson at Tune+ www.adamtuned.com
1x Airaid Modular Intake Tube for 2015+ Ecoboost Mustang (450-930)
1x AEM DryFlow Drop In Filter for 2015+ Ecoboost Mustang (28-50029)
Suspension
ISC Coil Overs: http://www.stranoparts.com/partdetails.php?PartID=1387&CategoryID=314&ModelID=40
Rear Sway Bar: http://www.stranoparts.com/partdetails.php?PartID=1289&CategoryID=296&ModelID=40
Front Sway Bar: http://www.stranoparts.com/partdetails.php?PartID=1394&CategoryID=296&ModelID=40
Dif Bushings: http://www.steeda.com/steeda-s550-m...nsert-system-urethane-2015-ecoboost-555-4443/
Misc
Clutch Spring: http://www.steeda.com/steeda-s550-mustang-clutch-spring-assist-35-lb-in-15-16-all-555-7022/
RedLine Tuning Hood QuickLIFT PLUS System
Wish List:
- Lighter Wheels and better tires *Advice needed
- Lighter Seats *Advice needed
- Racing Harness/Seat Belt
- Lighter Battery Battery: Thinking this Scorpion http://www.scorpionbattery.com/powersports-batteries/motorcycle/sstx12b-fp.html
- IRS Subframe Bushings http://www.steeda.com/steeda-s550-mustang-irs-sub-frame-bushing-support-system-2015-555-4437/ (Need to find some non metal ones)
Front Camber = -3.0
Front Cast = 7.5
Rear Camber = -2.0
Wheels
o 19"x9" wide
o 42mm offset
o 6.8" backspacing
o o 33.00 lb (s)
Tires
Exhaust
Engine
Suspension
Misc
Wish List:
