Hopefully this helps future searches - the S550 Seat Swap compilation that contains almost everything needed for seat swap questions for functions and/or airbag info.
Leather Seat Owners:
What is and is not Warrantable regarding upholstery issues:
https://www.mustang6g.com/forums/th...d-gsb-18-7042-used-to-be-gsb-g0000129.112230/
Cloth Seat Owners:
https://www.mustang6g.com/forums/threads/cloth-seat-owners-ford-gsb-g0000006.112228/
SEAT SWAP info between S550 OR other model years (Power vs. Non-Power, heated/cooled vs base, wiring info, air bag info, etc.):
How to swap in S550 seats into PRE-S550 Mustangs (or other vehicles) and getting the seat controls and heating/cooling functions working. This is courtesy of @CV428 and @lkeltner:
https://www.mustang6g.com/forums/th...controls-are-not-present.168750/#post-3622500
Ton of seat swap info (as well as going from non-power to power and resolution of airbag lights):
https://www.mustang6g.com/forums/th...gt-mustang-air-bag-light.131615/#post-2726858
Base to premium
https://www.mustang6g.com/forums/th...r-swapping-from-base-to-premium-seats.129230/
@Brian_S550 thread on how to work with the seat harnesses when upgrading to power seats (great tech thread that could benefit Recaro swaps too):
https://www.mustang6g.com/forums/th...n-base-s550-surprising-solution-found.108075/
Wiring info:
https://www.mustang6g.com/forums/th...er-seat-move-ability-fix.130275/#post-2690135
This one discusses 18/19 Recaros into prior model:
https://www.mustang6g.com/forums/th...a-19-fit-in-a-16-premium.153995/#post-3146151
This link has more popular "seat" threads so hope something is helpful
https://www.mustang6g.com/forums/threads/replacing-recaros.149574/#post-3055441
There is this thread from another site that is interesting because there seems to be a sensor near the seat track on Recaros (again based only on the tech in THIS thread):
https://www.fordgt500.com/threads/airbag-light-on-after-recaro-power-base-swap.25241/
And here’s another Recaro thread from an M6G member @Blkbear17 who did the swap and includes more tech info:
https://www.mustang6g.com/forums/threads/18-19-recaro-in-15-17.112219/
Thanks to @Nickel for this write up regarding proper way to fix airbag light when swapping GT350R Recaro seats into a GT::
https://www.mustang6g.com/forums/threads/airbag-light-after-gt350r-recaro-install.141811/
This thread contains good tech and is from another site; the discussion is how to put in aftermarket seats and deal with the seat harnesses and airbag light issues:
https://trackmustangsonline.com/thr...sor-when-installing-sparco-front-seats.13245/
More related tech on how to put the S550 Recaros into earlier Mustangs - but this one contains good tech about the seat harnesses that could help the S550 community - so clicky and scroll down to the images discussing the harnesses:
https://themustangsource.com/forums...ats-my-2013-gt-comfort-package-535447/index2/
Ford Performance PDF for how to put Recaros into S550 and airbag light info:
https://www.mustang6g.com/forums/th...gt-mustang-air-bag-light.131615/#post-2726867
How to swap or replace damaged airbags in a Recaro seat. Thanks goes out to @Shepherd308 for his tech on this subject matter:
https://www.mustang6g.com/forums/threads/recaro-airbag.181796/
Braum Racing Seat install wiring info into an S550 (thanks goes out to @dirtwarrior):
https://www.mustang6g.com/forums/threads/racing-seats-in-a-mustang-wiring.174479/#post-3539546
Heated and Cooling Seat Tech:
See this thread which outlined the heated/cooled seat module problem:
https://www.mustang6g.com/forums/threads/heated-cooled-seats-mystery.152156/
This thread is about members who have found that the harness connector was shorted - but in most instances it affects the seat heating/cooling aspect.
https://www.mustang6g.com/forums/th...ing-no-more-click-cant-find-the-relay.112533/
Massive Heated/Cooling seat thread geared more towards the seats not cooling:
https://www.mustang6g.com/forums/threads/cooled-seats-not-cooling.23384/
Seat TEDs:
This thread is helpful which has images of the TEDs:
This thread contains images and user write ups on how to remove the upholstery which will allow access to the TEDs:
https://www.mustang6g.com/forums/threads/how-to-cloth-removal-and-leather-install.30323/
Here's more TED (“peltier”) tech for others:
https://www.marlow.com/how-do-thermoelectric-coolers-tecs-work
https://www.oemcarandtruckseats.com...r-conditioned-car-truck-seats-work-the-basics
Repair and diagnosis, per another Ford site for similar TEDs:
http://ww2.justanswer.com/uploads/s420/2012-08-07_200851_03_navigator_seat_tests.pdf?r=aw|85386|0&awc=7742_1533862812_b595925e0aa522fef423c6915ef663b3
Ford Shop Manual wiring info (applicable to 2015-2017, possibly could be applied to 2018+ but proceed with caution in the event there's harness changes):
https://www.mustang6g.com/forums/attachments/sm_16-pdf.520403/
I had put together this thread a while back for how to remove wrinkles or imperfections from leather upholstery:
https://www.mustang6g.com/forums/th...-or-remove-dents-wrinkles.72454/#post-1992614
How to do leather or cloth seat upholstery swaps or recovers:
https://www.mustang6g.com/forums/threads/factory-leather-swap-has-begun.177662/
Katzkin discussions:
https://www.mustang6g.com/forums/threads/katzkin-or-leatherseats-com.115885/
How to install Katzkin:
https://www.mustang6g.com/forums/threads/katzkin-leather-install.143766/#post-2982692
Custom Cover upholstery discussions:
https://www.mustang6g.com/forums/th...tone-leather-seat-covers.160079/#post-3394932
Rear Sear Delete info:
GT350 rear seat delete w/video, thanks to @pilotgore:
https://www.mustang6g.com/forums/th...emoval-and-install-diy-tutorial-video.174505/
Ford Performance rear seat delete:
https://www.mustang6g.com/forums/th...rformance-rear-seat-delete-first-look.167138/
Coverking rear seat delete:
https://www.mustang6g.com/forums/threads/coverking-rear-seat-delete.169546/
OEM delete:
https://www.mustang6g.com/forums/threads/oem-rear-seat-delete-question.168075/#post-3434654
EMP rear seat delete:
https://www.mustang6g.com/forums/threads/emp-rear-seat-delete-kit.165779/
Shrader rear seat delete:
https://www.mustang6g.com/forums/threads/shrader-rear-seat-delete-black.158969/
SVE rear seat delete:
https://www.mustang6g.com/forums/threads/aftermarket-rear-seat-delete-kit.154942/#post-3157641
2020 GT500 delete:
https://www.mustang6g.com/forums/threads/2020-gt500-rear-seat-delete.140693/
Rear seat delete pics:
https://www.mustang6g.com/forums/threads/rear-seat-delete-pics.166730/
2021 FYI for rear seat delete, rear has two wires:
https://www.mustang6g.com/forums/threads/2021-rear-seat-belts-have-a-2-wire-connector-°.159905/
DIY for deleting rear seat in a Convertible:
https://www.mustang6g.com/forums/threads/2019-vert-rear-seat-delete-diy.162060/
Rear seat "undelete":
https://www.mustang6g.com/forums/threads/cftp-rear-seat-un-delete.160394/#post-3268214
Rear seat delete plus rollbar:
https://www.mustang6g.com/forums/th...hrader-rear-seat-delete-install-video.157490/
Cloth Seat Owners:
Base to premium
Wiring info:
Seat TEDs:
OEM delete:
2020 GT500 delete:
