GT350 Recaros in a 2016 GT Mustang Air Bag Light
Discussion in 'Cosmetic/Visual Mods (Exterior + Interior)' started by 5.0Dave, Nov 15, 2019.
  1. 5.0Dave
    5.0Dave Active Member
    Vehicle(s):
    2015 Ford Mustang GT Base
    Jan 9, 2016
    Atlanta Ga
    Hi I recently swapped out my 2016 Premium mustang seats for a set of GT350 Recaro Seats. For some strange reason the air bag light is on. But it plugs in normally. Could someone lead me into the right direction in solving this issue. Thanks
  2. Nagare
    Nagare Well-Known Member
    Vehicle(s):
    2017 Lightning Blue V6
    Feb 1, 2017
    Ft Lauderdale
    3,777
    1,974
    Garage Profiles:
    Are they 2015-17 Recaros? If they are from a 18+ car, different airbags so it'll cause the light. Beyond that, I got nothing that can help.
  3. Fangi0
    Fangi0 Well-Known Member
    First Name:
    Oscar
    Vehicle(s):
    GT Base PP2
    Nov 28, 2018
    Atlanta, GA
    59
    I am curious about this as I was thinking about doing the same seat swap. Subscribed. BTW, if you don't mind me asking, where did you get the GT350 Recaros (I see you are also in Atlanta)?
  4. OP
    5.0Dave
    Vehicle(s):
    Jan 9, 2016
    Atlanta Ga
    I got them from a friend that was trading his car in. He got them out of a wrecked GT350
  5. Cobra Jet
    Cobra Jet Well-Known Member
    Vehicle(s):
    Feb 12, 2015
    5,864
    2,847
    Rating:
    100%
    3   0   0
    Regardless if the seats are the standard, heated/cooled or Recaros - this thread may help with the air bag light:
    https://www.mustang6g.com/forums/threads/seat-replacement-airbag-issue.74306/
    As far as the harnesses are concerned:
    Even though the harnesses did connect without issues, the pin outs are different between Recaros and the standard bucket seats.
    Another thing to mention too - the harnesses for the seat airbags are different from 2015-17 to 2018-current (and most likely different from GT350 to GT/EB body harnesses).
    Even though your harnesses connected, the airbags are most likely disabled (usually when the light is illuminated). You’re going to have to source a wiring diagram and probably move the pin outs around (or do your own splicing). It would be necessary in order to get the proper connection via wire contacts based on wiring colors from a Recaro equipped S550 to a standard equipped S550.
  6. Cobra Jet
    Vehicle(s):
    Feb 12, 2015
    5,864
    2,847
    Rating:
    100%
    3   0   0
    There is this thread from another site that is interesting because there seems to be a sensor near the seat track on Recaros (again based only on the tech in THIS thread):
    https://www.fordgt500.com/threads/airbag-light-on-after-recaro-power-base-swap.25241/
    And here’s another Recaro thread from an M6G member @Blkbear17 who did the swap and includes more tech info:
    https://www.mustang6g.com/forums/threads/18-19-recaro-in-15-17.112219/
    This thread contains good tech and is from another site; the discussion is how to put in aftermarket seats and deal with the seat harnesses and airbag light issues:
    https://trackmustangsonline.com/thr...sor-when-installing-sparco-front-seats.13245/
    More related tech on how to put the S550 Recaros into earlier Mustangs - but this one contains good tech about the seat harnesses that could help the S550 community - so clicky and scroll down to the images discussing the harnesses:
    https://themustangsource.com/forums...ats-my-2013-gt-comfort-package-535447/index2/
    2morrow likes this.
  7. Cobra Jet
    Vehicle(s):
    Feb 12, 2015
    5,864
    2,847
    Rating:
    100%
    3   0   0
    Did someone say they wanted the Ford Performance docs discussing the installation of Recaros and airbag light?
    shazam:
  8. Cobra Jet
    Vehicle(s):
    Feb 12, 2015
    5,864
    2,847
    Rating:
    100%
    3   0   0
  9. 2morrow
    2morrow DesignR/DriveR/RiceEatR
    First Name:
    Todd
    Vehicle(s):
    '16 Mustang GTPP
    Nov 15, 2015
    415/707/925/530/916
    4,704
    3,246
    0   0   0
    This may help. I specifically address the airbag light issue.
    Peedystablo82 and SmokinAces like this.
  10. taylor.crandall1
    taylor.crandall1 Well-Known Member
    First Name:
    Taylor
    Vehicle(s):
    Mustang
    Jan 23, 2015
    San Diego
    62
    Great video! Thanks for making it and thanks for all the info.
    Two questions,
    Is all that is needed for both driver and passenger is a 2.2 ohm resistor? Anything else needed?
    Also, where did you put the passenger side bladder? In the actual Sparco seat underneath the cushion?
    2morrow likes this.
  11. 2morrow
    First Name:
    Todd
    Vehicle(s):
    '16 Mustang GTPP
    Nov 15, 2015
    415/707/925/530/916
    4,704
    3,246
    0   0   0
    Hey thank you, I appreciate the feedback!
    You'll need to solder the resistor into the 2 wires mentioned but thats about it. I really cleaned up the wire harness because I'm OCD.
    I placed the passenger bladder underneath the passenger side base. I also made an acrylic cover to really clean up that side because again, OCD lol.
    Eventually I'll probably get another seat but nowadays a lot of the events that I signed up for and the SCCA group that I work in doesn't allow passengers.
    With that being said, you could probably put it in between the fabric and rigid seat but there is a plastic receiver with a tube that reads the pressure and
    that might get uncomfortable for your passenger even if you do shift it to the side/thigh area.
    Let me know if you have any other questions, I'm happy to help!
    taylor.crandall1 likes this.
  12. taylor.crandall1
    First Name:
    Taylor
    Vehicle(s):
    Mustang
    Jan 23, 2015
    San Diego
    62
    Thank you so much for the response!
    I appreciate your OCD. I like everything to be and look as close to OEM as possible. I have had aftermarket seats in several cars and have always found a way to defeat the airbag light and I am glad I now have way for the new Mustang. I can't stand dash lights.
    Thanks again!
    2morrow likes this.
  13. Peedystablo82
    Peedystablo82 Well-Known Member
    First Name:
    David
    Vehicle(s):
    2017 mustang GT pp Paxton e85
    Apr 1, 2018
    VA
    260
    Occupation:
    Owner of ZAP Electric LLC
    0   0   0
    Hey bro, so I tried this technique and my airbag light was still on when I did it. I used a 2.2 Moon resistor and did it the same way you did it. The only thing I did not do was I temporarily just wrap each wire around each end of the resistor. Just to give it a good good connection. Does it have to be soldered for it to work? I mean I do electrical work, and I know the wires were very good and connected to each end of the resistor.
    2morrow likes this.
  14. 2morrow
    First Name:
    Todd
    Vehicle(s):
    '16 Mustang GTPP
    Nov 15, 2015
    415/707/925/530/916
    4,704
    3,246
    0   0   0
    Soldering should isn't a prerequisite but I soldered mine for a good connection. Did you test the wiring harness after connecting it and before wrapping it all up with E-Tape?
    -T
  15. Peedystablo82
    First Name:
    David
    Vehicle(s):
    Apr 1, 2018
    VA
    260
    Occupation:
    0   0   0
    I did not stick my meter tester on it to measure the ohms, but I did try to start car and air bag light was still on.
Loading...
Share This Page
