Doctor Fishtail
Like the title says what are y'all using or recommendations. Do not want to exceed 700WHP. I was under the assumption that a BAP would be fine.
Your car is way overbuilt to only be 708 rwhp. Lots of room to crank it up.I was advised fore triple pump so thats what I purchased.
That's in the works. I'm going for 1000rwhp. Just don't have official dyno sheets. But its in the works.Your car is way overbuilt to only be 708 rwhp. Lots of room to crank it up.
I will not be doing a triple pump setup. Seems overkill for what I want. This Roush charged Mustang is quick as is I just want it a bit faster.I was advised fore triple pump so thats what I purchased.
Fore Level 1?? Do you have a link?fore level 1. $1200ish from beefcake. do that.
There is so much more than a triple pump to get there. :thumbs: I do not want to travel down that street. 700 whp and I am good.That's in the works. I'm going for 1000rwhp. Just don't have official dyno sheets. But its in the works.
I found this but already have the tuning. These kits are priced with tuning.fore level 1. $1200ish from beefcake. do that.
E85 for FI without a fuel system is asking for serious trouble. Fuel isnt something you play around with.BAP for E85 and 9-10 lbs be just fine for 700.
Can't hit 675-700 with pump?Like the title says what are y'all using or recommendations. Do not want to exceed 700WHP. I was under the assumption that a BAP would be fine.
My tuner told me the same thing.E85 for FI without a fuel system is asking for serious trouble. Fuel isnt something you play around with.
Have not tried yet. Still running Stage 1 Roush injectors and 90mm pulley. Raw fuel smell sucks. This is one reason want to go back to Korn. Figured I would go smaller pulley with BAP but does not look like a good idea.Can't hit 675-700 with pump?
I need to check with my tuner if he is ok with the Fore kits. I know he does not want a BAP. And he likes the ID injectors as I do.Call beefcake tell him what you want to do. He can tell the right kit for your needs. The fore kits are quite nice.
