Recommendations for 2017 Mustang Performance Pack brake replacement?
Metz3020827
Arizona
Connor
2017 Mustang GT
Looking for recommendations for a rather stock besides suspension and exhaust 2017 GT Performance Package. My front brakes have 56k miles on them and they’re in need of replacements now.
not looking to break the bank, (no I’m not looking to cheap out but I don’t need a set of rotors and pads for $600.)
should I just stick to OEM?
Bluedream
omaha,NE
2016 GT DIB premium pp, 2017 Focus RS
Oem are good with initial bite but i found them to dust way too much. Switched to power stop Z26 pads(i think thats themodel or Z23). Work just as good less initial bite but stopping power is the same and way less brake dust. Run these pads on my focus rs as well and they work great!!
Therealmattlex
Mn
2015 mustang gt
I 2nd the Z26 pads. I bought them from rockauto. They are about $70. I've run 3 HPDE with these and zero brake fade. I'm going to be replacing these in the spring and sticking with the same ones. I feel like the initial bite is less aggressive but overall braking feels just as strong. The main reason I even tried these was because there is way less brake dust.
Metz3020827
Metz3020827
Arizona
Connor
2017 Mustang GT
Just the pads? Stick to OE rotors?
Metz3020827
Metz3020827
Arizona
Connor
2017 Mustang GT
Third the Z26s. The provide equal if not better braking than stock, less dust and for 1/3rd the cost.
What about the rotors? Stick to OE? Or get matching powerstop?
EFI
Masshole central
5.Br0
Depends on what you're doing with the car. If it's just for the street, nothing more than OEM (or OEM like) is needed. For a heavy use track car, you might benefit from some better alloy but at that point you'll probably need a better pad anyway. Just get something that has some sort of coating on the rotor hats and vanes to prevent rust.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Replace your rotors when they've worn below the depth to replace them. Until then no need to touch them unless they're in bad condition in some way.
As for pads, the OEM ones are pretty fantastic if you can tolerate the dust. If you want something which dusts less, you're probably trading off some heat tolerance, so that just depends on your needs.
Metz3020827
Metz3020827
Arizona
Connor
2017 Mustang GT
The rotors are definitely getting there. They need replacing for sure.
Metz3020827
Metz3020827
Arizona
Connor
2017 Mustang GT
Just street driving, no track/strip.
kz
West Chester, OH
Mustangs & F150
Have you measured thickness with a caliper ?
Lots of people tend to think they need replace pads / rotors when they're nowhere near that point.
Rear brakes especially need replacement pretty much never.
Metz3020827
Metz3020827
Arizona
Connor
2017 Mustang GT
Sooooo do I take them to go get turned somewhere? I’m sure they’re alright. They still stop on a dime, it’s just my brake pads are worn down so much.
kz
West Chester, OH
Mustangs & F150
Just throw new pads on unless they're different than what you've been using (compound-wise) than use a sand paper to clean them. But check first if the pads are low. I've changed pads in the pads and it turned out I change pads to change them, not because I needed to.
FeebleExpert
Bellevue, WA
Craig
2019 GT Roush Stage 3 A10
PowerStop Z26 pads are great! If you're keeping the same rotors get them turned.
luc
CA
2017 GT with PP
Just get the cheapest blank you can get from rockauto
….and before anyone says that you need “better”, it’s what i have been using ( with Cobalt xr1 pads ) for years on my track car with no issues whatsoever
