"Rear Axle Differential Temp Increased, Decrease Speed" warning
EXP Jawa
Rochester, NY
www.torsen.com
Rick
1999 Cobra Convertible, Electric Green
We are talking about regular GTs , they have no axle coolers
We're talking about axle cooling, which has implications beyond just the GT. Do you think that nothing discussed here is of interest to the owner of a GT350? Anyway, as noted, it never hurts to keep things in perspective. The point being that if a someone does, in fact, add a cooler, that should be should be a consideration in oil weight chosen.
Also wildcatgoal, FWIW, Torsen doesn't specifically recommend 75W140 anywhere. Rather, what the vehicle manufacturer recommends in most situations still applies, and what the ring & pinion manufacturer recommends if that's been changed. It just so happens that Ford used the 140 a lot until recently. My personal thought is that 75W140 offers a lot of all-around benefits for the reasons that you've mentioned, but would come at the price of a (minor) loss of drivetrain efficiency. My own experience shows that the 75W85 is a kind of crappy lube...
Grintch
Hunstville
2015 GT PP
Not of interest to a GT350 owner because those already have a diff cooler, or at least the track pack & R's do. And the Track pack was rolled into the base GT350 for 2017.
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
293F seems pretty hot for a diff.
I have a 2016 non-PP GT with auto trans (no diff warning system). I wrapped my exhaust around the diff, put in 140wt, and put on a temp sticker of range 250 - 320F.
Had an all-day track day, of pleasant 75F ambient temp. The temp sticker didn't even register the first dot. :shrug:
wmfateam
Arizona
www.facebook.com
Whitey
2017 LB GT PP
I had a very intense track day on Saturday, 2017 GT PP, never received a warning or anything. Three sessions (25 min, 20 min and 15 min) and a three lap Time Attack. In AZ at about 80-90 degrees. Still on stock fluid that had one other track day.
EXP Jawa
Rochester, NY
www.torsen.com
Rick
The aluminum carrier probably sheds heat a lot more readily than the iron one does. Combine that with the exhaust wrap, and maybe you've found a happy place...
wildcatgoal
@sirboom_photography
TBD
I wrapped my exhaust and didn't get a heat warning the last time I was at RA. It was at Gridlife and the traffic was f'ing terrible (number of people should not have been in my calss) but I got a couple good sessions in and never a warning.
Jeffy_2010
Missouri
Taylor
2015 gt 6-speed/ performance pack Oxford white
Update, full tilt boogie has released a diff cooler
DB83
Granny Shifter
Spain
2017 Mustang GT
Am i missing something with the full tilt boogie kit? How exactly does air travel through the cooler when it's butted against the floor like that?
NvrFinished
So Cal
2016 DIB GTPP
Yes, it's offset from the bottom with a fan that draws fresh air through the cooler. I think Steeda has a similar setup with the cooler inside the car.
DB83
Granny Shifter
Spain
2017 Mustang GT
By offset you mean there is a gap between the body and the cooler? If there is, it's pretty small!
I'm sure they've done their research, and it works. Just looks a bit tight.
DocWalt
SE PA
GT350
I had the same thought. I'm sure they don't want it hanging lower to keep it away from any possible debris, but I'd rather have a bigger gap than that
