Lavien
My understanding was that the 2.0L EB4 such as the one in the Focus ST has peak torque come in at 2500RPM but the overboost feature allows it to produce between 5-10% more torque between 3000-4500RPM.Please keep in mind that the Ecoboost motors are well known for having their peak torque come very early in the RPM range. The Ecoboost 2.0L in the Focus ST has peak torque come on at 3000 RPM. The 5.0L comes in at 4250 RPM and the 3.7L comes in at the same value. So I fully expect the 2.3L at 310/310 would have similar values at which point, provided the gearing is the same, the Turbo 4 would be either quicker due to weight differences or the same.
As for your assertion that if you want to autocross keep buying the 5.0L, well, for most of us who autocross, that much HP has limited uses, especially in the lower classes where we are required to keep relatively narrow street tires where the power is a detriment. As is the added weight. If the Turbo 4 is indeed coming at 3200-3300ish lbs and the GT at the 3400-3500lbs, there is a certain advantage there. As an autocrosser, I'm not interested in the 5.0L as an autocross motor, what I am interested in is the Turbo 4, it's reduced weight, and it's reasonable power levels.
Regardless, I have yet to drive one but I hear its good fun. If I were to get the I4 it would be for daily use so a few other things would be of importance beyond your autocross needs. Certainly weight savings is a bonus for both worlds but fuel economy will be a big bonus for my DD commuting needs on mostly highways. Another concern I have is the 2.0L in the Focus ST has been described as "cemetery quiet" at idle and really despite the electronically enhanced sound symposer even with a heavy foot it just lacks that throatyness that will be needed for a Mustang. But we'll see what kind of magic Ford can do with the I4 in that regard.
