Planning centrifugal
sdskinner73
Indiana, United States
Shawn
2018 premium GT A10 3.55s
Looking for some advice on a “safe” build. Currently planning to go ESS G3 next year. I am currently sitting at FBO in my Gen 3. A10 Stainless works headers, cat back exhaust, steeda hardcore CAI, e85, wengerd tune, and 170 thermostat. I emailed with Wengerd on my plans related to his side of things. I’d like to aim for 650-700 wheel range. He recommended G3 over G2 in the event I want to increase power at some point.
Besides the below, I was planning to add the steeda ultimate stop the hop kit. Brakes need changed sometime soon, may do those over winter with the kit.
Anything else recommended I may be overlooking? I have 295/35/19 rears currently, not sure when/if those need upsized. Also driveshaft, half shafts, etc. may go with wengerds fuel system eventually as well. I think the 650-700 wheel is more or less safe before building the trans becomes important. This is a street car. If I go down a drag strip, it would be rare.
ESS G3
120mm pulley
Standard impeller
Satin color
Standard 50mm BOV
ID1050XDS injectors
DW415 fuel pump
18-23 model year
VMP FPB
High precision straight gears
G3 spec intercooler
robvas
MI
2011 GT
You don't necessarily need to go bigger but you're going to want some drag radials.
Other than that your list looks fine. I wouldn't get the straight cut gears though. That gets annoying really fast. I would add a real boost/vac gauge while you're at it.
2020 MagneticPP1
CA
Michael
2020 Mustang GT Premium PP1
Why the FPB if you're upgrading the pump? I thought the FPB was only if you're not going to upgrade the pump? I could be wrong, but that was my understanding.
sdskinner73
sdskinner73
Shawn
I may upgrade that later, so it made sense to me to do it now. It’s the difference of a few hundred dollars.
sdskinner73
sdskinner73
Shawn
DEFINITELY get some stronger Half Shafts. You add the Stop the Hop kit (I have it on my car) and 600+ HP and sticky tires, those stock shafts are living on borrowed time!
Are the 350 HS good enough, or is the FP the way to go? Hell of a price difference there, but that’s why I’m planning it all out now.
Bob Lob Law
Jeff
'22 GT 401A ESS A10
I personally LOVE the straight cut gears!!! Had them for a year next month and 20,000+ miles and it's still one of my favorite sounds to hear! It's whistle is a sweet symphony! LOL
Zrussian13
Phoenix
You can probably get away with one or the other at that power level but the dw pump was designed to run at 18v. For a couple hundred extra bucks that's good insurance you'll always have plenty of fuel.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Centri noises are hard to beat!
Justgonna send it
NC
Ty
2019 GT 6spd ess G3 kit 120mm pulley , wendgerd tune & 2020 hpp eco
I need to get some upgraded ones myself
daSNAK3
Cary, IL
Jake
2021 GT
Just do the boost a pump or fuel pump, don't need both. Either way if you decide to get a fuel system ever and turn it up, you won't need either of them, seems like a waste of money to get both.
sdskinner73
sdskinner73
Shawn
Run your fuel questions by your tuner
I was hoping to not inundate him with questions. It’s Wengerd, who’s been great. But I’m sure he’s got plenty of others to answer to when plenty here have the knowledge.
robvas
MI
2011 GT
They want you to ask them what you should run so you don't try to get tuned with a TEMU fuel pump and injectors and then spend a week trying to get it to run right
sdskinner73
sdskinner73
Shawn
That’s fair. He gave me the below answer for now. I am not sure if I actually want to turn it up down the road, and trying to avoid pissing away money when I can plan it out. Big one I see people get burned on is injectors. While 55lb is enough for this goal, I was thinking buy once cry once for the 1050XDS. Per his response, I really don’t need the DW415 now but will for E85.
My original plan was actually the G2, but the G3 seems to be the better deal for future potentials.
Yes the G2 with the G3 intercooler is capable of that power level on 93. If you do plan to turn it up a bit more in the future, we would recommend starting out with the G3 kit as it will allow for more if you plan to go E85 in the future. On 93 fuel, the stock pump with a BAP and 55lb gt500 injectors can handle the 120mm pulley which is the smallest pulley we recommend for 93 fuel. If you go to E85, then you will need a fuel system.
