OPG/CS Options - Preparing for SC
BigD94
BigD94
New Jersey
Dom
2016 GT
I'm doing FI upgrade this coming fall. In my past of building engines, I always replaced the assembly's as a unit when possible, Not just the internal gearing, IE oil pumps, fuel pumps ETC.
Good luck.
With the full FP oil pump unit, would I need to be open it up and lube the gears before install? The product page says its pressure and flow tested, but you never know.
DougS550
Fishers, Indiana
Doug
I am sure the OPG assembly will come lubed But For Me, I will open and apply assembly Lube accordingly prior to installing. But that's me, you will make your own decision. Good luck.
BigD94
BigD94
New Jersey
Dom
2016 GT
Thanks for the help man
brianbr
Surprise
Brian
2019 Magnetic GT PP
It does not come lubed! You must prime it before installing by pouring fresh oil in the inlet and spinning the assembly.
larr12
Alberto
2020 Mustang PP1
I was thinking in this the other day. Any opinions on also installing the MMR chain guides, seconday guides and primary chain tensioners?
BigD94
BigD94
New Jersey
Dom
2016 GT
It's probably a good idea to replace them. Definitely not essential, but it's a nice addition. Someone in another thread said to use MMR tensioner, GT350 primary, MMR secondary (GT350 secondary won't fit).
I'm not planning to run high boost or go too crazy with my build so I'm probably just going to reuse the stock parts. However, If I find a good deal on the upgraded components then I'll do that.
LethalPerformance
Fl
2020 Shelby GT500 CFTP, 2021 Whipple'd F150
We've used the Boundary combo before on Goldmember. They were the only engine upgrade we did with the Whipple 3.0L to go 8.64@157. Feel free to reach out if there's anything we can help you guys with. We have Boundary, MMR and Ford Performance parts available to ship.
#teamlethal
gameovergt
Kevin
Lake Asbury, FL (Jacksonville area).
Kevin
2022 Ford Mustang GT California Special (A10)
Link to Ford Performance OPG/CS? Oil cover? I have a 2022 GT & not sure the page 1 links will fit.
engineermike
La
2018 GTPP A10
It appears as though FP discontinued the only opg you could be confident in.
LethalPerformance
Fl
Not for gen3.
Correct. The Ford Performance oil pump gear isn’t even available anymore and the crank sprocket is only for Gen 2 engines.
I ran Boundary on my 8 sec Gen 3 car and never had an issue. They’re priced well and work great so that’s typically what I recommend.
Slopoke
Left Coast.
Ed
2019 Mustang GT PP1 10R80
Just a heads up. If you are planning to do the gears yourself, you have to lower the front of the oil pan, if it's the composite type pan. You have to do that so the oil pickup tube will come free from the oil pump. I used a 14" 1/4 extension, along with other lengths depending on where the bolt was, plus a 10mm one piece swivel socket.
Even though I said only the front needs to come down, you should remove all of the bolts and lower it, that way you can run your finger along the whole length of the seal to make sure it's in the correct position.
