Need Help With Boost Setup
22Coyoti
Matteo1822
Matteo
2022 Mustang Gt Premium
I need to make a decision this week for a boost setup for my 2022 Mustang Gt A10 car. I have narrowed it down to ESS G3 Setup with a 125 MM pulley BAP and gt500 injectors, or a whipple stage 2 complete kit using whipples tune. I have read all the forms and I’m having a hard time deciding on which way to go. I want to keep on stock headers and cats, i’d be happy with 600-700 whp. I’m running a drag Pack setup currently. When you look at the cost there’s not much difference once you get the tuning for the ESS. I will not be using e85, Looking for a 91/93 tune. I know the ESS is better for higher rpm but will it also help down low compared to stock? I’m worried that the ESS won’t have the power below 60mph, I know both are reliable, I just can’t make the decision. For suspension wise should I be running BMR Cradle lockouts with vertical links, or The Starter Steeda Stop the Hop. I’m looking for a daily street car that will see the track once or twice a year.
What do you guys recommend?
Your Help would be greatly appreciated!
Thanks in Advance.
DougS550
Fishers, Indiana
Doug
Thanks in Advance.
I would recommend searching this forum for this discussion been discussed ALOT!!. ESS would be the easiest route and lower in cost. It just depends what you are expecting and what are your end goals. Goid Luck
Wolfys11
New york
Jakub
2023 Mustang Gt
On auto setup, all is great for boost. Ess is cheaper and louder for autos
CrackedHorn
Kansas
09 Mustang GT/CS; 15 Mustang GT
Roll racing type speed ? Ess
20-80mph? Whipple
Neither is bad. Centri is easy to control on the street
22Coyoti
Matteo1822
Matteo
Thank you, Much appreciated
TonyT930
Philadelphia, Pa.
Tony
2017 Mustang GT Convertible in Ruby Red
Thanks in Advance.
ESS will be easier to control on the street and easier on the transmission, rear end, and axles.
  • Like
Reactions: RNM
daSNAK3
Cary, IL
Jake
2021 GT
Stop the hop works for my G3 w/ 100mm pulley.
engineermike
La
2018 GTPP A10
I know the ESS is better for higher rpm….
They’re actually about even up top.
We’ve proven capable of arguing technical aspects for days at a time, but everyone seems to agree the pd makes more low and mid rpm torque than the centrif. This part is owner-preference. Personally, I feel like the stock coyote is lacking torque and the pd really fills in what was missing. A pd naturally augments a high-reving dohc engine's torque curve, whereas a centrif doesn’t help it much in the range where it’s already weak. Personally, I like the pedal response and want it to “feel” like a massive big block, and have made a bunch of changes to increase part throttle low rpm torque even further.
I also don’t believe anyone who says the low/mid “hit” of a pd is uncontrollable has ever actually driven one.
Furthermore, you can use tuning to give a pd the exact same torque curve as a centrif if you like (but not vice versa). No one seems to do this, though.
22Coyoti
Matteo1822
Matteo
Thank You for your detailed Response
robvas
MI
2011 GT
Can you really turn it down to basically stock levels of torque on the low end?
DougS550
Fishers, Indiana
Doug
I agree a PD at 650-700 with Sticky tires is totally manageable with a little common and respect since. Lol. But, Boosting around 16 lbs on a Whipple is challenging to say the least and takes a little more common sense and respect. But I choose the PD because I wanted unbridled Instant power. Either way, they all satisfy your "Need For Speed"!!
engineermike
La
2018 GTPP A10
Absolutely. You can shape the torque curve however you want it.
In my Roush truck, I have 3 torque curves programmed in. One is related to flex fuel, limiting it to about 10 psi when it learns gasoline, one is for heavy or long-distance towing where I’ve limited it to the stock torque curve and shift points, and finally the unlimited mode for learned ethanol and normal, manual, or sport modes. You can also shape any of them to ramp torque up, down, flat, torque by gear, or whatever pleases you.
