MGW Shifter Install!
Epiphany
Global
I like to disassemble things.
Raise the motor or transmission? No. Tip the rear of the transmission down via lowering or removing the transmission crossmember? Yes. Allows for more room for your hands.
DocWalt
SE PA
GT350
Nice thread, thanks!
Blame imgur for the picture issues. They're aggressively blocking sites that have classifieds sections because "you're using our servers to make money"
madlag
madlag
Snake Charmer
NC
2018 GT350R, 2022 GT500
Do you have to raise the motor or tranny as MGW does at the factory for install? If not, why does MGW lift either the motor or tranny to install the shifter and you didn’t? Looks great.
you remove the transmission support brace allow the transmission to "sag" down a bit and support it with your floor jack. I'd it it lowers it 6 inches or so. four bolts, very straightforward. Follow the video and you're good to go:
Blue Raptor
IL
ZL1 1LE, GT350, Ford RS, F350 Dually, Explorer
All that for a shifter swap!?!? F that. :doh:
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Epiphany
Global
madlag
madlag
Snake Charmer
NC
You say that because you haven't tried it. Its the shifter that belongs with that Tremec..
The GT350 needs it less than say, a regular GT, but it's a fantastic product.
More like "that's all there is to a shifter swap?" Yes!
Exactly. :headbang:
Tank
9/11 - Never Forget
Above the Notches
G0853
Another thing I saw folks mentioning was a that there wasn't enough loctite. I had more than enough! Enough if not, its just standard BLUE found at any parts store.
Nice post and pics [MENTION=35566]madlag[/MENTION] :thumbsup:
I was the one who warned you about the loctite. I think if I got the tube you showed a pic of, I would have had enough. I got a smallish ‘ketchup’ sized squeeze packet that probably could have been enough if I hadn’t been so paranoid about vibration:D.
I got my shifter for Xmas so maybe MGW upsized what they send w the shifter.
ForTehNguyen
Houston, Texas
15 GT
having a skinny arm or a friend definately helps get that front bolt out
did my non GT350 MGW on jackstands in 3 hours taking my time and this is before they came out with the new design that cuts the time in half
easily the best mod to the car, you interact with it 100% of the time driving the car unlike most mods.
madlag
madlag
Snake Charmer
NC
I was the one who warned you about the loctite. I think if I got the tube you showed a lic of, I would have had enough. I got a smallish ‘ketchup’ sized squeeze packet that probably could have been enough if I hadn’t been so paranoid about vibration:D.
ah yes! I thought about you each time I used the little tube lolol. You're right though, any less (like from the little packet) and I wouldn't have had enough.
madlag
madlag
Snake Charmer
NC
I agree with this. The more I drive it, the more I appreciate the change.
galaxy
St Louis
'17 GT350
I've never ever installed a shifter in something where it wasn't a great mod and well worth any expense or effort. As good as the stock shifter is on this car in comparison, I'm still excited. Going in sometime this week/end.
madlag
madlag
Snake Charmer
NC
Let us know how it goes. Can't wait to hear!
cking
17GT350AG/BS-MGW/UPR/ABLIP
Mark where tranny mount bracket is before you loosen it, it won't go back to the same spot without a little push. Helps prevent NVH
