Measuring oil - Cold vs Warm
rick81721
Venice, FL and Flemington, NJ
Rick
2017 GT350 LB H6153
4. Fast forward to today where I am just under 1000 miles. I drove the car pretty gently in the first 500 miles, a few brief runs up to 6k RPMs from 500 to 700 miles. From 700 to about 825 miles, several wots, several shifts at 8250 rpm. When I returned from that run, hot oil level was 1/8 inch above bottom hole. And Ford sez this is "ok."
5. Today, knocked out about 150 more miles, mostly highway, rarely ever going more that 4k rpm, mostly cruising in 5th at 80 mph. very limited decelerations using engine. Hot oil reading is still above bottom hole by maybe 1/16th of an inch and Ford sez this is "ok."
Do I have an oil usage problem? Maybe and maybe not.
Are you waiting long enough after shutting down to take a reading? Seems odd to see such a drop after 1 easy drive of 150 miles. I'd do some cold readings after she's been sitting overnight.
johnny1
The owners supplement says to shut off engine and wait 15 minutes for the oil to drain back into the oil pan. And that oil should be between the top and bottom hole on dip stick. Says nothing about checking it on a cold engine (like over night sitting) I've always checked my vehicles before starting them in the morning. I don't know, maybe this voodoo engine has a more accurate reading on dip stick when the oil is warmed up (and let sit for 15 minutes after turning engine off as stated)
Wriggly
Illinois
2018 Porsche 718 GTS
I have consistently seen negligible difference between hot and cold checks. My car is at 2560 miles currently and the level is just about a sixteenth of an inch below the upper hole. I'd guess that the consumption on my example is pretty good at this point and speculate it'll use about a quart every 7500-8000 miles.
I'm content with the results I'm experiencing. :)
BlkGT3
Hot Spot
13 GT86 Autox, 16 GT350 TP, 06 Civic Si TTD car
All this worry over a few on ounces of oil. Let's put in perspective if you are one qt. low you still have 90% of the oil in the engine. A few ounces difference between cold and hot is nothing to get your shorts tight about. If it is showing on the hash marks drive the car. When it gets a qt. low add oil. Easy Peezy ;)
Peter
Krogen
Puget Sound
2017 GT350 Oxford White & Blue Stripes
Gosh.... I don't recall reading so many obsessions about checking a car's oil level! It's really simple. If it's at or below the bottom hole, add a quart.
The capacity is 10 quarts; we're talking 10% here. There could be more capacity variation from car to car than that. Just make sure it doesn't get very far below the bottom hole and don't overfill it.
geddy lee
c/o Solar Federation
Germany
Hi folks,
I found the thread as I am dealing with the exct question - what is the correct oil level when hot/cold.
I have been a the Ford dealship for an oil change - and this morning when the engine was cold I checked the oil level :
It is at the top hasmark - prolly a tiny tiny tiny bit above the the hashmark (see the picture)
Would you guys consider it as ok - or overfilled ?
Deleted member 37397
Guest
Hi folks,
Did you happen to check it 15 minutes after you parked it at home? Curious where the level was.
Hack
Minneapolis
Mustang, Challenger
Hi folks,
Looks ok to me. I wouldn't touch it.
geddy lee
Germany
Not yet, I will do so this afternoon (I am located in Germany - so don't worry :-D)
I will check it in the same place and take a pic.
EDIT : I guess it will reach until the upper hole - hope it will not exceed it.
Next question : What is the correct direction for the disptick to insert - the hashmark showing on the upper side (towards the passenger side) or the hashmark on the lower side (pointing to the driver side)
My picture was taken with the hashrmark on upper side - pointing to the passenger side)
DCShelby
DC
Robert
It really does not matter which direction you use.
JAJ
Vancouver BC
2016 GT350 Track Pack
So, Ford's instructions are that "full" is anywhere between the two holes. That means that the hash marks don't count - maybe they're for a different engine or something. What you're seeing on the dipstick after an oil change is what we all see - solidly between the holes and maybe slightly above the hash marks that don't count.
The way I manage my oil level - my car consumes about a litre every 3,000 km - is to check it occasionally hot or cold and add 1/2 quart or litre when it gets close to the lower hole. It doesn't matter if it's hot or cold that way - it never gets too low, and because you're only adding half a bottle, it never overfills either.
galaxy
St Louis
Which ever one makes you feel better! Seriously!
geddy lee
Germany
So, back from a 45 Minute drive - motor still warm the car was sitting for 15 minutes in the garage - and here you go :
I am not sure but somehow I am far away from being happy :crazy: At least this is what they call : Do not add any oil.
But is it already too much ?
Nfs1000f
Upstate NY
Neal
Don’t sweat it. It’s not enough to matter.
JAJ
Vancouver BC
It's fine - don't worry about it. The patchy coverage at the very top could just be pickup from inside the tube - it doesn't get solidly covered until below the upper hole.
