DougS550
- May 18, 2020
- Fishers, Indiana
- Doug
- 2019 GT Premium A10 PP1 Whipple Stage 2
Thank you for your help. I agree with you, I do not want to get rid of my OS whipple H/E for those exact reasons for I am a "What IF" man. I decided I will go with IC Chiller (Charlie). He has been very helpful and I have his direct number which he answers immediately, and I am not waiting for a reply email from Australia if I have issues. He said he will help me 100% through my install as well as any future issues/concerns I might have. I told Charlie I wanted to keep my whipple OS H/E and he said he has a Bypass adapter kit ready to go so I can keep it. It involves installing a bypass valve and running a toggle switch/wires to the inside of my car, for me to mount the switch. Then when I get into traffic or want to play, all I do is turn it on and walla, Chiller Chilling. Because right now, even at 14-15lbs boost, my Mishimoto 3 core radiator, OS Whipple H/E and the 170 degree thermostat, Mishimoto oil Cooler, I have only seen my electric radiator fans come on a few times driving in stop and go traffic. And thats with my tuner lowering the threshold Temp of when my fans turn on. So this is just for those times when I need it.Yes, I went with FI.
I did however ignore his rantings because I don't trust ditching the heat exchanger and I'm not looking to get the IAT "chilly" as much as I am trying to keep it from getting hot.
I just need it to not get into deep triple digits and I'm more concerned with the steady state performance than some sorta of stored, build up max chill at the drag strip.
So I plumbed the system in sequence. I have an ice tank (no ice) in the rear for more fluid capacity (more heat sink) with a PB400 pump that pushes coolant forward, through the blower/intercooler, from there it goes to the heat exchanger, from the heat exchanger it goes to through the chiller and then from the chiller back to the reservoir.
In this setup, if the discharge from the blower is cooler than ambient temps, then the heat exchangers actually HEATS the coolant. In most loaded situations, the discharge from the blower is above ambient, so the heat exchanger serves it's original purpose, just at reduced temps.
In this configuration, if the A/C system takes a shit, then my car simply returns back to a traditional heat exchanger setup. That way I'm not stuck on long trips if the compressor craps out or the compressor clutch, etc (which I've had happen).
To minimize temps, they want to eliminate the H/E and the more stored solution is a loop to/from the reservoir and a loop to and from the reservoir to the blower.
I considered having a middle ground and doing a loop to/from the reservoir and the chiller and then just have my normal loop from the reservoir-blower-h/e-back to reservoir, but this would require running two pumps and I'm already over budget on electrical load with a modest radio amp and fuel system. So I elected to go with a single serial loop.
If electrical loads weren't an issue I'd have done the split loop.
IN their recommended configuration, the chiller tries to super cool the fluid under low load conditions and then when you mash, the fluid going to the blower is cooler. This is why they don't want the H/E because again, in low load, if the fluid comes out of the intercooler at lower than ambient, the H/E actually adds heat back.
So in the end, it's all about a combination of what risks you're willing to accept.
I also don't really like the operational/power configuration and I may update that in the future. The way it is right now is that the A/C system operates the chiller all the time and the interior cabin A/C some of the time. I would rather have full flexibility to turn both branches off or turn one or the other on or both. But living in FL, it's not the end of the world because I don't drive the car in conditions where I would want to cut the A/C all that often (it can damage it if you try to run it in too cold of temps) and I don't go to the drag strip (despite claims, I'm really worried that even with all the insulation and shielding that the car will still drip on the track if it's really hot/humid even with the cabin loop cutoff).
Thank you. Chat later
