How difficult to switch to flat bottom steering wheel?
Jerry Carguy
Michigan 48169
Jerry
2021 California Special Black exterior
Been looking at some, could use the extra room for getting behind the wheel. But, I hate anything that requires removing the air bag. 2021 GT.
Inthehighdesert
NM
Charlie
It’s not a big deal. Disconnect the negative, remove the wheel, install the new, reconnect. It’s roughly a half hour job.
rxryanm
KY
2019 GTP PP1
Incredibly easy but sounds like it's a no period if you're not into removing the airbag.
galaxy
St Louis
Why do you hate removing the air bag? Disconnect the battery before starting the job. A fear of blowing the airbag is extremely low, and typically 99.47883625% self induced if you’ve ever seen some video of it happening.
LOL WUT
Illinois
19 GT
As others stated, it’s a simple job and perfectly safe with the battery disconnected.
Gnatsum21
Fort Lauderdale FL
Former: GT 21 Roush Twister Orange RIP | ECO 2016
I remember removing the airbag housing (the middle part of the steering wheel including horn) was a major P.I.T.A.
But I will do it again..soon with my new ride.
:like:
hchf1234
Florida Fort Myers
Lucas
2020 Mustang gt 10 speed
disconnect the battery touch the positive and negative cables together to get arrid of and parasitic draw and wait like 5-10 min with battery disconnected
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
The hardest part is releasing the clips to get the horn/airbag released. Left side was easy, but right side I had to attempt multiple times. Ended up making a tool with a groove in the end so the spring would not slip off.
End result was worth it:
luca1290
Italy
Luca
You don't need to rice out your car to have extra room to get in or out. You will certainly hit the steering column way before hitting the wheel itself.
junits15
MA
Justin
2019 Mustang GT
Disconnect he battery and there is no possible way the airbag can go off.
They need to be electrically triggered and they are extremely stable when not set off. Think about how few cases of airbags just going off there are. You'd have to do something supremely stupid to set off the airbag with the battery disconnected.
Jerry Carguy
Michigan 48169
Jerry
Thanks for some real content!😎
SheepDog
Colorado
Dax
Yeah, because the OEM steering wheel in these cars is so nice.👎
SheepDog
Colorado
Dax
Disconnect both battery cables from the battery and touch them together, this will discharge the capacitors. Use the long end of the largest allen wrench that will fit into the holes to release the springs on the airbag, and be gentle at first, as sometimes the wiring for the buttons can be in the way, and you don't want to damage them. You just push straight in towards the column
