Hellion TwinTurbo Install Cranking Issues
IceMan706
Virginia
Jacari
2021 Ford Mustang GT
Got my kit on and I started it for the first time the vehicle started and idled for a second then cut off and I tried to keep starting it wouldn’t turn over just kept cranking what could be my issue I ended up getting the cranking time exceeded message what could be my issue I attached a video down below.
Pistol_91
Clearwater
2020 mustang GT
Did you try any troubleshooting?
19BULLITTwhipple
Ramzi
Bullitt 2019
Check to make sure…
bov and gates have all unused ports plugged
check maf orientation it’s probably upside down
smoke test the car. I had this issue and it turned out to be a leak. Get a real smoke tester
check the plug gap
test all pumps in hat to make sure they are working
make sure you didn’t take out a fuel fuse or relay during install and forget to put it back in
make sure your fuel filter and check valve are going the correct direction
make sure you ran a vacuum line to fuel reg
19BULLITTwhipple
Ramzi
Bullitt 2019
Also make sure the tune is correct.
I bet the issue is one of those npt ports aren’t plugged
And don’t vent one side of the pcv
if you have a catch can either vent both or none.
you’ll induce a vacuum leak if you just do one side
Last suggestion would be to make sure the correct fuel is in the tank. 91/93 not e85
IceMan706
Virginia
Jacari
I didn’t know I had to plug the ports I thought I could let the ones on the solenoid and the wastegate vent to atmosphere
IceMan706
Virginia
Jacari
On the Mac valve? Send a photo of it
Give me a couple seconds but I’m running my plumbing like this I have the top ports of my wastegate venting to the atmosphere I have them bare though no silicone tubing hanging from them and have the bottom ones connecting to the solenoid.
19BULLITTwhipple
Ramzi
Bullitt 2019
and is it a 3 port or 4 port?
Which controller?
and are you using C02 or compressed air?
19BULLITTwhipple
Ramzi
Bullitt 2019
Jeez you have two Mac valves. Did you plug the other one? That doesn’t have a port going to a gate?
I’ll check the instructions I think I can pull them up.
@NGOT8R if you have time can you check this out?
IceMan706
Virginia
Jacari
I did actually I have 4 ports on each wastegate I plugged the two on each wastegate and just used the other two I’ll show you what I mean in a second
NGOT8R
Adrian
2019 Bullitt
It’s eboost3
When did the eboost3 come out? I knew they were working on it a while back. I saw a short video of it back then. Had I known they were coming out with to the EB3, I wouldn’t have bought the EB2.
The good news is they say the wiring is the same, so it’ll be as simple as unplugging and swapping them out.
IceMan706
Virginia
Jacari
When did the eboost3 come out? I knew they were working one it a while back. I saw a short video of it back then. Had I known they were coming out with to the EB3, I wouldn’t have bought the EB2.
I hooked it up the polarity doesn’t matter for the wires
19BULLITTwhipple
Ramzi
Bullitt 2019
So both port 1’s to atomosphere
both port 2 to fitting on turbo
and both port 3 to bottom of gate
looks simple.
did you check the gates for any open unplugged fittings? And did you wrap each fitting with teflon tape?
I had a fitting loose on my blow off valve and it caused the car not to start also. I think you gotta smoke test the car.
just to be safe . See attached photo
