Engine fuel pressure too low during cranking.I ran a code scanner I was getting a p00c6 code
Yeah I have fic1000’s, I have my regulator running to both bov’s now but I had an ess kit before so I only had one bovEngine fuel pressure too low during cranking.
You probably don’t have the regulator set correctly
Did you remember to install the correct injectors?
your regulator is supposed to run to the vacuum block. It’s probably not working properly if you have a line going to both blow off valves. It seems vacuum and boost from the manifold.Yeah I have fic1000’s, I have my regulator running to both bov’s now but I had an ess kit before so I only had one bov
can you take a photo of your regulator and the lines you have. I’m assuming you have a tee fitting from the regulator to both blow off valves. That’s probably your issueyour regulator is supposed to run to the vacuum block. It’s probably not working properly if you have a line going to both blow off valves. It seems vacuum and boost from the manifold.
I could be wrong but my assumption would be that would only see boost and not vacuum.Yea I do have a tee fitting for both bov lines I’ll snap you a picture
Did you figure out the no start issue?Yea I do have a tee fitting for both bov lines I’ll snap you a picture
