Engine Tick Preventive Measures
Vlad Soare
Bucharest, Romania
Vlad
2020 Mustang GT 6MT
I've noticed that the majority of newer DI engines from all brands are just noisy as hell.
Yes, they are, but that's a different kind of noise. It's rhythmical and blends naturally with the rest of the noises. When you hear it, you think "mmm... this engine's a bit noisy", and not "oh my God, this engine's broken".
Mopa
Peachtree City Georgia
Michael
You really should be using the highest octane you can at the pump, the cost savings of using 87 aren't worthwhile especially if you live in a hot climate or it's summer in a northern climate. The car will pull crazy levels of timing as the guy above said. I don't think it will cause damage but it will just make shit for power.
Also, I get why people are concerned about engine noises, but I've noticed that the majority of newer DI engines from all brands are just noisy as hell. My VW 2.0 was clattery and there was nothing wrong with it.
I will heed your advice since I don’t want to take a chance damaging the engine. Gas is plenty cheap right now. Thanks.
308 Cal. Bullitt
Midwestern-former Left coast
Dee
'22 GT500 + other 2/4/& 6 wheeled trash barges
No problem. I get it. There have been many threads over the years on gen2 and gen3 engines and the oil to use. Everyone has a brand of their choice but I just did not remember anyone using 5w-50 except for maybe road racers. It’s just too heavy for day to day.
Agreed, any @ 50w on top end of product spectrum is way to high viscosity for these production engine programs from Ford and others.
We only use heavy viscosity oils in high
(Large) bearing clearance, forced induction application for 3.7sec - sub 6 second ETs in time time constraints@ the drag strip of
(1/8 mile & 1/4 mile venues.. Brad Penn 50w-60w-& on hot says 70W...totally different situation@55+lbs of boost on over 500", w/81+lb all billet crankshafts, and alum rods that hav a life span of 5-25 passes , depending on your tuneup)
As for the Ford Motorcraft 5-20 that was recommended eng oil in the 5.4L 3V -
F150s from ~'04-'10. That was proven to be the downfall of the clogged screens on the cam phasers which let to massive noise/ticks/more, and nearly ruined or did ruin 10's of thousands of engs. The 5.4L 3V we are referring too is THE MOST RECONDITIONED ENG FIR REPLACEMENT PRESENTLY ON FACE OF THE PLANET. PERIOD)
( let me preface all this above, by 1st saying we hsve always been a huge advocates of using manufacturer recommended lubricants and other item)
On the 5.4s, total disaster and failure likely, but not in all cases. Tge guys who ran FULL SYNTHETIC STUFF like BG products or others, got well over 200k w/ZERO cam phaser issues, ticks, clogged screens, stretched chains)
There is no magic bullet, but if you do NOT LOCK OUT CAM phasers pn these 5.4s, you better run full synthetic in 5w-20. If not, you will likely as an owner suffer unwanted consequences.
Does this same idea apply to the '18 & newer 5.0 Coyote, and do not yet hav thd evidence to support that. Am I willing to risk running the recommended semi synthetic again in another Ford Cam phaser engine.. Hell no..
Maybe for breakin.. but thats about it.
We run 5w-20 AMSOIL in our Polaris turbo RZRs, and genuinely see, by careful monitoring,
that oil temps are across the board LOWER duringoverall varied operating environments,
As we switch to it 1st on our previous non turbo machine, and see a small but recognized temp variant of oil between the 2 oils. Factory recommended, and Aftermarket higher shear w/nice specs all around.. ( Amsoil)
Also on our newee Turbo 1000, we measurable amts in a lower operating Temp in degrees°,
than the "Polaris recommended oils" of standard or Higher performance versions.
Imnot telling anyone to run any type of oil.
I am sharing the REALITY that Fords Semi- synthetic 5w20 Motorcraft, when driving short distances , daily to wrk, then hm, is not the optimal oil we found too be acceptable.
It does appear if your driving a lot of mikes on each startup, vs like 10 ea way per day, that the Ford Semi seems to fair much better on its treatment to the Cam phaser screens , which can clog w/micro particle debree above 150k, and cause some issues-too total engine failure.
Im a dealer by default for the 2 largest engine (production) rebuilders in the nation. They both said tgat 5.4-3v is by far the most replaced eng of all in the US, and has been for for several yrs now.
Does this relate to the S550 Mustang.
From 30,000 ft elevation, looking down, maybe not. The 6.0 Ford diesel suffers its own problems, requiring the $6k delete package to save it from itself as well. But again, the guys who own them, and get in and drive long trips daily, or when in use, have WAY LESS Problems with the Added Ford emissions equip that was not intended originally from International.
Ford sued International over all the failures and lost.
Why, cuz International proved in court of law, the had 100,000s+ of these in use, that were not kaden w/Fords emissions equipment, EPA induced protocol's, components, like in every diesel school bus for yrs. These non EGR emission component engines did not have tgese failures.
Nor did the engines that seemed to be driven long distances all the time, vs short grocery runs and only to drop kids off at soccer practice daily.
I dont use any BG stuff myself, never really bought into it, yet see a really close friend and his father, both reps for BG, use it in everything, and had none of the Ticks and valve train noises, or any types of failure's, on there 5.4s, unlike litterally , most of the rest of the owners of these engs from 04-10.
I state all this, because there might be a lesson from this past issues , that may spark some interest in doing owners of S550s , own due-diligence, on whether or not the recommended Ford 5w20 Semi-Sythetic, is what they want to go with.
I look bk w/regret, following Fords protocols/recommendations/and even chgd my oil regularly, before necessary by there standards.
When I had my cam phasers locked out, and all related parts replaced, I can only say, had I know about the 1000s of pages of documents on this issue existed, I would have done something..
while most live on forums and chat rooms gir yrs, I was working 7 days a week, half days minimum (12hrs) and usually closer to 16 hrs..
I hadno time for forum ( nonsense too me @time, as it doesn'tpay the bills or keep 1/2 dozen employees workin, vs looking at the chicks next door, or whatever..)
My supplier's would often call bout 7am,
( to verify a fax'ed in parts order nite before, well 6 hrs before..)
asking if id even been hm yet.?? Im like yeah.. Wtf..???
"yes id answer, why??"
"Ur fax is time stamped 1:30am, and its 7am now, and @ both times u were at your shop"??
Yep, I got hm by 2am.. up @ 6am.
here by 6:45am .
My point, till I semi retired, I had zero time to see any benefits from a "greater collective", of knowledge, on any kind of forums/message board.
Mostly cause any forums in my field to start w/were guys who were not actually making a living building professional race cars, or differential's.
I was physically working in shop, from beginning to end of day, for decades.
As an owner, and previous employee.
When I finally tried this community thing, I learned I could hav avoided a bunch of heartache over an issue, many have had... and many may also disagree with why.
As to the causes, that is.. So a community of varied opinions , although a great resource, its only as good as how you feel you can apply it to your specific situation.
Cuz till this stuff ( online forums) came along, we realied SOULY ON EXPERIENCE, of our own doing, or perhaps a trusted colleague.
Which we rarely communicated on these sorta topics anyhow, as we are all
ego maniacs, (admittedly or not..)
I found anyhow, till we get to be about 25 yrs into our specific craft..
Some communication was done via internet (email, since about 1995 for me)
Without any collective or internet help,
Built our 1st all 4130, Fully Fabricated 9" rear end housing, for a 1200hp car,
in ~Oct. 1993.. No internet to get drawings of a Ford differential pattern in CAD From.. or any tips on the pit falls of building a
Fab 9", (& there are many)
or how to interally control oil, under high speeds of those gears/bearings spinning.
We had to learn from the "Success's of Others", as Professionals.
Your last choice was too learn from your mistakes, "as an ametuer does".
Ask 100 people, get a 100 answers on oil brands, viscosity's, filtration, and chg intervals.
If you have decades of real world experience, it helps, alot on your decisions.
But again, so does this collective community of forum based sharing,
and learning, ( helps alot)
& now of others relate there experience and knowledge as it pertains to our subject cars.
I alway followed Manufacturer's recommendations on stock vehicles.. Till the 5.4L debacle. That jaded us into looking beyond those recommendations, when your vehicles use and circumstances are perhaps varied from the "typical use by majority of said car owners".
Based on my experience as of late, 5w-20 is sufficient for anything less than track use, but the Semi-synthetic recommended oil Ford suggests, and likely demands use if for warranty, us not going to be my 1st choice after an oil chg or 2.
So only thing left is to determine if the base stock of full synthetic Motorcraft 5w-20 will meet our own expectations, not your or anyone else's here.
As we are not suggesting you do anything we say.
We are stating what we learned from real world experience, which can often, till proven wrong, be the best path to an acceptable outcome of durability and performance.
Lastly, I chg my oil every 500-750 miles in my 50'S GMC TRK, w/509" BBC @ 659HP.
I have cases of new filters, and cases of my preferred, high zinc content oil, that I use.
Its $6-$8 a quart via internet or most places, but my local speed shop sells it too me 2 cases at a time for $3.39 a quart.
For me its entertainment to chg my oil now days, in my DD pump gas 50s Trk.
. I like doing it. So criticize all you want about how ridiculous it is to chg oil under 1000 miles.
Its got over 36k miles on it, runs like an Indian w/its feathers on fire,
and doesnt use any oil. Chg ot too qwik clearly..lol.
My only complaint is the aero package of '53, above 120 mph, is rather poor.
GMC engineering did not have down yet.
Trk was designed torun bout 53 mph then.
If Im too poor to buy the best oil I feel I can fafford, to run in my car,
then Im also too poor to OWN MY'19
S550, 480hp, 308", Dual over head cam powered vehicle to start w/.
And no, I wont chg oil in the Bullitt every 750 miles or less.
But it wont be 5-10k either.
Maybe recycle it into 1 of many beaters that gets reg 5w-20 mineral based/petroleum based cars/trucks...
( doubtful, but it could happen...im just to lazy to do that to my own standards of filtration, between oil swaps thou, when lil debrisgets in ur collection pan on any oil chg.)
50w seems a bit thick for w/bearing clearances of say, anything under 35/50lbs of boost ...
Im just the dumb NG w/opinion.
Do not listen to anything I say.
Do your own due diligence..
Regards,
D.
We need a Tick and Rattle sub-forum...
:devil:
Elp_jc
None
I thought Mustang Coyotes weren't going to have these issues (like the F-150s), but seems like I didn't research enough. Ha ha. Oh well. Hope my car doesn't do that awful noise; so far (300 miles), it doesn't. Having said that, no way that noise hot is piston slap IMO. It sounded like a bad con-rod bearing, or even a bad main bearing; just awful. But guy who sent me the video said 'Ceratec' quieted the 'tick', so it can't be a bearing or that wouldn't happen, correct? Therefore, the only other logical cause IMO has to be the cam phasers (only on the intake on Coyotes), which are a constant issue on F-150 engines (both 3.5EB and 5.0s). If that's the case, you want the thinnest oil when cold to get to the phasers asap, and prevent wear due to lack of initial lubrication. Second, if you use an oil too thick at operating temperature, it could also affect proper lubrication when hot.
I'm thinking of changing oil for the first time at 1K miles, and switch to either PUP 0/20, or M1 0/30 (for quicker cold-start lubrication than 5/20 or 5/30). The M1 0/30 is a 'thin' 30 weight, so it'd be within 20 grade range most of its 5K-mile life (there's no PUP 0/30). And of course the stock FL500S oil filter, since it for sure has the correct relief valve pressure. Does my logic sound reasonable? As inferred, I'll change the oil every 5K after the first time. With that in mind, do you guys think my engine might be better off with PUP 0/20, PUP 5/20, or M1 0/30? I use M1 0/30 on all my other vehicles; I switched from 5/30 when it became available, since there's no drawback. I think PUP is a better oil than M1 for what I've read, but not entirely sure. I'm always open to change to better things, even if it's just for this car. What I don't get is why some engines don't have any tick when new, and then all of a sudden they do after an oil change; there must be using the wrong oil for the engine. No other explanation. But it makes no sense that a semi-synthetic oil is better than full synthetic, so it has to be the grade. Does Ford put 5/20 in there? I'm suspecting they don't, with 5/30 instead, but it's just a hunch :). Or maybe some other kind of 'break-in' oil? You can PM me if you don't want this to turn into another oil thread :D. Thanks gang.
OnThree
2015 mustang GT
My 15 GT pretty much ticked the day I bought it and it was LOUD too. Got even worse when I did a 18 manifold swap for some reason. I beat the complete shit outta that thing, I'm talking road course with daily driving and redline pulls everyday. The engine never gave me any problems so I wouldn't worry too much about a little tick.
Fwiw, I ran 5W-40 in mine as a daily. I don't think running a 5W-50 would hurt anything but if you are just farting around town there's no point to go that heavy. If you're really hard on the car then maybe, if track use then go for it. The Boss 302 coyote ran 5W-50 and I don't believe the gen3 are vastly different from those so should be zero problems with "clearance" on engine bearings etc
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
The factory fill is 5W20 Motorcraft Synthetic blend. Personally I'd wait until 3000 miles to change the oil. Any sparkly bits will get caught by the filter anyway so it's just a waste of money to change it any earlier than the "severe duty" schedule. 0W oils are usually better in the cold but give up a little bit when warm, there's rarely a free lunch. So unless you live in an area that sees subzero temps regularly in the winter I'd pass.
Elp_jc
None
Indeed. And that's exactly why I'm thinking of going with M1 0/30 :). Flowing better than 5W when engine is cold (at any temperature), and basically being at the higher end of the 20 weight range when hot, sounds like a win-win for the engine, no? :D I'd honestly be VERY hesitant to use any oil additives on this (or any other) modern engine. Manuals actually say not to do that, so hope I'm not forced to make that decision. Ha ha.
Bikeman315
Myrtle Beach, SC
Ira
No. If Ford thought 0-whatever was best for our Coyotes they would have specked them that way, especially up North. Do what you want but unless your on the track or SC'ed go with the manufactures recommendations. There just isn't any reason not too.
Elp_jc
None
The '0-whatever' is a non-issue; ALL such oils are fully compatible and approved by all manufacturers (and yes, both 5/20 and 0/20 are approved on my Bullitt manual, page 309), since again, there's no drawback. They lubricate quicker when cold than 5W, even if it's 90-deg outside. Where there might be an issue is with 20 or 30. But again, like everything else, not all 20 grade oils or 30s are created equal. You have oils that are at the low, middle, or high end of that range. A high end (or 'thick') 20 weight is almost the same as a low end ('thin') 30. Another reason for 30 weight is fuel dilution, which would lower a 20 weight oil beyond acceptable, but not sure if it's a real problem on 5.0s or not (like it is on EBs).
Finally, this particular oil issue is not something I trust Ford with. Why? Simply because they're reportedly doing it to appease the EPA, since they certified our engine using 5/20 (for the highest possible MPG), and they need to recommend it, even if engineers preferred 5/30. In fact, many other countries recommend 5/30 (Australia, Japan, Taiwan, etc) on exactly our same engine; how do you explain that? :D
Bikeman315
Myrtle Beach, SC
Ira
Of course you can use 0- but look at Ford's recommendation, not approval.
Alternative Engine Oil for Extremely Cold Climates
To improve engine cold start performance, we recommend that you use the following alternative engine oil in extremely cold climates, where the ambient temperature reaches -22.0F (-30C) or below.
When was the last time the temps hit -22 in El Paso, TX. :) Kind of like gas, Ford approves of 87 but recommends 91/93.
As far as 5W-20 & 5W-30 Mexico and Canada have the same recommendations as the US. Considering the warranty issues/costs that could arise in using substandard grade oil to appease the EPA, not likely.
Motor oil (U.S.): WSS-M2C945-B1
Motorcraft. SAE 5W-20 Premium Synthetic Blend Motor Oil
XO-5W20-QSP
Motor oil (Canada): WSS-M2C945-B1
CXO-5W20-LSP12
Motor oil (Mexico): WSS-M2C945-B1
MXO-5W20-QSP
Motor oil for track use (U.S.): WSS-M2C946-B1
Motorcraft. SAE 5W-30 Premium Synthetic Blend Motor Oil
XO-5W30-QSP
Motor oil for track use (Canada): WSS-M2C946-B1
CXO-5W30-LSP12
Motor oil for track use (Mexico): WSS-M2C946-B1
XO-5W30-QSP
So if i understand you correctly, you gave Ford $50k for your Bullitt but do not trust what they are recommending for something as basic as engine oil. Fascinating.
Elp_jc
None
you gave Ford $50k for your Bullitt but do not trust what they are recommending for something as basic as engine oil? Fascinating.
Yep. And not 'fascinating'; just smart :D. Do you trust Ford with its 10K-mile oil change intervals? Do you trust Ford to use regular fuel in your Coyote? That's what they recommend. If you answered 'yes' to either or both (which I REALLY doubt), then I'd be more 'fascinated' than you. Ha ha. And it has nothing to do with trust; it's just the reality we live in, where lawyers and/or EPA have more say in many things (including those 3) than engineers; it's up to you to apply common sense, and decide what's best for your car. Oh, and in case you didn't know, ALL manufacturers are now moving to 0W/xx oils, since again, there is NO drawback: you have quicker lubrication on cold start-ups, which is when the great majority of engine wear happens. And equally protected at operating temperature. But if you just can't make sense of that, let's put it to rest, shall we? I WILL use 0W/xx oils, period (like I do on all my vehicles). And let's focus on the actually more 'controversial' aspect, which is 20 or 30 weight when hot :)... because that's where the engine spends almost 100% of its life.
Finally, I wanted to touch base with the widely used 'CeraTec' additive. I DO NOT doubt the multiple testimonials that it works... but the better question is this: What the heck is it doing to the oil? Is it converting it to a 30W? 40? Or even 50? Has anybody done an analysis to see what the cST of the combination equates to in a regular synthetic oil? My main concern using that stuff is there would be ZERO doubt to a dealer that you put some unapproved crap in your engine. It looks like freaking latte. Ha ha. I think it absolutely has to be increasing the viscosity of the oil, since that's what quiets the engine. I'd be inclined to first try M1 0/40 (which is what Porsches use) than that additive...if my car eventually develops that ultra annoying (and embarrassing) tick. And if it didn't work with that, then maybe 0/30 with Ceratec, but I'd like to know first what it does to the engine oil as far as viscosity at operating temperature. Has anybody with Ceratec has done that? Please post. Thank you :).
Bikeman315
Myrtle Beach, SC
Ira
Elp_jc
None
It's not about winning or losing; it's about what's best for our engines. There's no doubt about 0W vs 5W, since even oil at 100-deg ambient temperature is too thick to lubricate properly; that's why manufacturers are moving to 0W. What's more debatable is 20 vs 30. But since the Coyote was developed with 30, and Ford still recommends it outside of the US, I'm probably going to go with M1 0/30, which is a very 'thin' 30 weight, so almost like a 'thick' 20 weight. The 0W will lubricate the problematic cam phasers sooner than any 5W oil, which might prevent any future issues; that's also why I'll switch to it at 1K miles, most likely. If my engine ticks (hopefully not), might try M1 0/40, which is also approved by Ford in many hot climates (I live in hot TX). I prefer that than using an additive like Ceratec, since I have no idea what it's actually doing to the oil. We'll see. Hope my engine is happy with M1 0/30, so I'm not forced to go any higher than that. And you use whatever you want for your engine, and everybody happy :D.
Ontario
Paul
2019 Mustang GT PP1
I have read through many of these threads regarding the “tick” many opinions and “possible” solutions?
I just did my first oil change at just under 5000 miles and used a 5w20 full synthetic. Noticed the sound within the first 2 min of startup. So far I have found to be super intermittent, ticks less than it doesn’t.
What I find most interesting is the conflicting info, both from people on forums and from Ford.
Forum posts almost all say 5w20, my filler cap says 5w20, but my owner manual specs 5w30 or 50 for track use.
I will switch to 5w30 on the next change. Likely sooner than later
