Engine misfire problems
juan15gt
San Diego
juan
2015 GT 50th Anniversary Performance Package
Hello to anyone who decides to read this. I’m having some misfires after having the car sit for 3 months. I had my transmission rebuilt and it took a bit longer than expected, replaced clutch along with rebuilt trans. I’ve got the car running now but I have a misfire happening. I’ve got p0303 and p0305 popping up as well as a start up misfire detected. I’ll be driving and the car will start misfiring along with the check engine light flashing, after about 15-20 seconds the misfire will stop and the car will be driving like normal again. I noticed while the misfiring is happening the ac stops working and doesn’t blow cold. I’m a bit stumped, I’ve done the first parts of diagnosing, switching plugs, coils, and injectors but the codes are still the same to the cylinder. Is there anything I’m missing or should check?
juan15gt
San Diego
juan
Forgot to add I am FBO and tuned on 91 at the moment by AMR. Injectors were just replaced less than a year ago to 47lb from ford. Which is why I’m sure it wasn’t the injectors but still swapped
loucas-2021
Tamarac, FL
Louis
2021 Mustang GT PP Grabber Yellow
juan15gt
San Diego
juan
juan15gt
San Diego
juan
Crank relearn is necessary after a clutch replacement or else you'll get this
Oh wow I didn’t know that, I’ll definitely look into it and see how to do that, thank you!
MM777
Waiting for Feb 2017
Canberra
Mick
S550 Mustang GT, Manual, Magnetic
I had the same issue after a Mantic clutch install. P300, P304> P307 codes, did a crank relearn through my NGauge & that sorted the issue. I also had other codes at time, which turned out to be the rear wheel bearings & thrust washer throwing out the ABS sensors.
If your not familiar with the crank relearn procedure, here’s some additional links to help:
https://www.mustang6g.com/forums/th...s-weird-hesitation.125119/page-2#post-2679084
Also check this link if you have a n-gauge for crank relearn:
https://www.mustang6g.com/forums/threads/new-clutch-dtc-and-shudders.148583/#post-3035678
Crank relearn with SCTX4:
https://www.mustang6g.com/forums/th...des-codes-and-more-codes.146485/#post-2999715
Crank relearn with HPTuners:
M6G member @Jn2 crank relearn:
https://www.mustang6g.com/forums/threads/sct-crank-relearn-questions-please-help.69190/#post-1586668
Here's info for how to do KAM reset too:
https://www.mustang6g.com/forums/threads/kam-reset-magic.148830/#post-3040046
https://www.mustang6g.com/forums/threads/ecu-reset-how-to-do-it.36757/#post-897609
juan15gt
San Diego
juan
Thankfully I had my sctx4 with me and I was able to perform the crank relearn, all codes are gone and engine is running good again, thank you!
Good news! Stick around lots of great folks and tech here.
